WMC help - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By rc05
post #1 of 12 Old 08-14-2014, 10:53 AM - Thread Starter
ryu4000's Avatar
Quoted: 20 Post(s)
WMC help
I been using cable for a few months with hd homerun well my cable co just added the sec network it works fine on the boxes but when using the htpc no go it won't find the channel try scanning and everything that station just not there.i scan using hd homerun software i see it there but not wmc.
ryu4000 is offline
post #2 of 12 Old 08-14-2014, 11:13 AM
Sammy2's Avatar
Quoted: 550 Post(s)
Liked: 262
You probably need a CableCARD tuner such as the HD Homerun Prime.
If it is the case that you meant to say "Prime", you probably need to go back through the setup process for CableCARD tuners to pick up the added channel.
Sammy2 is offline
post #3 of 12 Old 08-14-2014, 11:16 AM - Thread Starter
ryu4000's Avatar
Quoted: 20 Post(s)
Yep i meant prime i did the setup in prime and wmc only prime i can get the channel to show but not wmc.
ryu4000 is offline
post #4 of 12 Old 08-14-2014, 11:23 AM
Sammy2's Avatar
Quoted: 550 Post(s)
Liked: 262
Okay. You need to start over from where you input your ZIP code and then select the right Digital Cable from the list. Also, make sure that you are authenticated for both your CableCARD and Tuning Adapter (assuming you have one of those).
Sammy2 is offline
post #5 of 12 Old 08-14-2014, 11:28 AM - Thread Starter
ryu4000's Avatar
Quoted: 20 Post(s)
Ok just try no go i'm not sure what i'm doing wrong but i know in the prime app it doesn't have a name yet for the channel it's blank it's suppose to be sec network that just came online today.
ryu4000 is offline
post #6 of 12 Old 08-14-2014, 11:33 AM
Sammy2's Avatar
Quoted: 550 Post(s)
Liked: 262
Do an update of the Guide Data in the Settings Menu.
If that doesn't do it then reset the Prime and the TA as well and try again.
Sammy2 is offline
post #7 of 12 Old 08-14-2014, 11:47 AM - Thread Starter
ryu4000's Avatar
Quoted: 20 Post(s)
Nope didn't do any different here you can see that it now showing sec instead of blank and well i check the zapit site and they show sec network on 802 for me also added a picture on what i see.I ask this other guy he getting the same issue so it might be a bit before they send the update to wmc clients.
ryu4000 is offline
post #8 of 12 Old 08-14-2014, 12:10 PM
ajkrishock's Avatar
Quoted: 80 Post(s)
Liked: 34
Can you manually tune to channel 802 using your remote/keyboard/whatever?
ajkrishock is offline
post #9 of 12 Old 08-14-2014, 12:27 PM - Thread Starter
ryu4000's Avatar
Quoted: 20 Post(s)
nope it won't even let me do that just stays on the same station
ryu4000 is offline
post #10 of 12 Old 08-14-2014, 12:33 PM
Sammy2's Avatar
Quoted: 550 Post(s)
Liked: 262
Looking at your guide up there I'm thinking you could benefit from MyChannelLogos.
Sammy2 is offline
post #11 of 12 Old 08-14-2014, 12:56 PM
rc05's Avatar
Quoted: 152 Post(s)
Liked: 87
If it's a brand new addition, the guide data probably isn't updated yet, so WMC has no idea the channel is there even if it's in the CableCARD map. You'll just have to wait for it to show up
Sammy2 likes this.
rc05 is offline
post #12 of 12 Old 08-14-2014, 01:43 PM - Thread Starter
ryu4000's Avatar
Quoted: 20 Post(s)
Yeah we just got the channel today so i guess i just have to watch it through quicktv till it updates on it's own.
ryu4000 is offline
Reply Home Theater Computers
