will this make a good HTPC? - AVS Forum | Home Theater Discussions And Reviews
 5Likes
  • 1 Post By ikkuranus
  • 1 Post By techmattr
  • 1 Post By mdavej
  • 2 Post By Barnahadnagy
post #1 of 16 Old 08-14-2014, 05:31 PM - Thread Starter
Liked: 0
I am looking at replacing my old Antec build and would like some advice on these components. A friend of mine put this together and I'm sure it will work good but I'm not sure about the HTPC function. I want to make sure it will work with my harmony universal remote, also, that are components or better bang for the buck. Thanks in advance for all The professional help.
http://pcpartpicker.com/parts/partlist/
jtevis is offline
post #2 of 16 Old 08-14-2014, 05:59 PM
techmattr's Avatar
Quoted: 71 Post(s)
Liked: 184
I've got that same board/cpu in my main HTPC right now. It overclocked to 4.2GHz without breaking a sweat. Loving it. I don't have any harmony remotes so I can't speak to that though. It's been my favorite HTPC so far and that's saying a lot coming from me since I've always sworn by AMD machines as being superior for HTPCs.
techmattr is offline
post #3 of 16 Old 08-14-2014, 06:27 PM - Thread Starter
Liked: 0
that is good to hear, thank you.
also just worried about forgetting something that I'll need for the HTPC Functionality.
the reason I picked that tuner is because it has a good reputation and includes the infrared receiver for the remote, so I don't have to buy it separately.
jtevis is offline
post #4 of 16 Old 08-14-2014, 07:00 PM
ikkuranus's Avatar
Quoted: 86 Post(s)
Liked: 53
I'm not sure if edits show up or not but his link is one that requires a login or cookies so what you are seeing is the last build you put together there.
Your link is invalid to everyone but yourself.
techmattr likes this.
ikkuranus is offline
post #5 of 16 Old 08-14-2014, 09:10 PM
techmattr's Avatar
Quoted: 71 Post(s)
Liked: 184
Interesting. It wouldn't have been my last build but it's possible I followed someone's last build that I viewed? I never entered any of that into PcPartPicker.
.... also if I click on the link in your post it does actually take me to my last build that isn't the same as what I was viewing before... either way OP should probably post a part list to get accurate feedback.
ajhieb likes this.
post #6 of 16 Old 08-15-2014, 03:58 PM - Thread Starter
Liked: 0
Sorry about that guys, how is this?
PCPartPicker part list: http://pcpartpicker.com/p/WtjTpg
Price breakdown by merchant: http://pcpartpicker.com/p/WtjTpg/by_merchant/
CPU: Intel Core i3-4150 3.5GHz Dual-Core Processor ($111.29 @ NCIX US)
CPU Cooler: Noctua NH-L9i 57.5 CFM CPU Cooler ($46.99 @ Mwave)
Motherboard: MSI H97M-G43 Micro ATX LGA1150 Motherboard ($88.99 @ Mac Mall)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1600 Memory ($84.98 @ OutletPC)
Storage: Samsung 840 Pro Series 128GB 2.5" Solid State Drive ($111.99 @ NCIX US)
Storage: Seagate Barracuda 3TB 3.5" 7200RPM Internal Hard Drive ($109.99 @ Amazon)
Video Card: MSI GeForce GTX 750 Ti 2GB TWIN FROZR Video Card ($134.99 @ Newegg)
Case: Silverstone GD05B-USB3.0 (Black) HTPC Case ($105.98 @ Newegg)
Power Supply: Corsair RM 450W 80+ Gold Certified Fully-Modular ATX Power Supply ($79.99 @ Micro Center)
Optical Drive: LG WH16NS40 Blu-Ray/DVD/CD Writer ($54.98 @ OutletPC)
Other: Hauppauge's WinTV HVR 2250
Total: $930.17
Prices include shipping, taxes, and discounts when available
Generated by PCPartPicker 2014-08-15 18:55
jtevis is offline
post #7 of 16 Old 08-15-2014, 04:10 PM
techmattr's Avatar
Quoted: 71 Post(s)
Liked: 184
I don't do any 3D playback so if you plan on doing that then I'm not sure about the needs... but you could save some money by getting a Pentium G3258 and have the option of overclocking it with that board. You don't need the discrete GPU unless you're planning on doing some light gaming (or possibly 3D?). You could probably save some money by getting a Samsung EVO instead of the Pro as well. Also 4GB of RAM should be plenty if it's just a HTPC.
post #8 of 16 Old 08-15-2014, 05:25 PM
mdavej's Avatar
Quoted: 2257 Post(s)
Liked: 985
Seems like huge overkill for HTPC duty. I'd definitely scale back on the video card and the RAM. My entire HTPC maxes out at 19W (the whole thing - CPU, drives, video), so it runs very cool and quiet without a lot of fans.
And I assume you don't have cable TV, just OTA, right? What exactly do you need this PC to do?
StinDaWg likes this.
mdavej is online now
post #9 of 16 Old 08-15-2014, 05:28 PM
Barnahadnagy's Avatar
Quoted: 71 Post(s)
Liked: 37
Depends what kind of HTPC. MadVR based HTPC would surely like the 750. Otherwise it seems to be a good mid range gaming PC with decent consumption.
2-channel is just multichannel done badly. - Frank Derks
Barnahadnagy is offline
post #10 of 16 Old 08-15-2014, 10:20 PM
ilovejedd's Avatar
Quoted: 76 Post(s)
Liked: 67
Personally, I'd scale back the 840 Pro to an MX100 and put the difference towards a Core i5. At a budget of $1000, there's really no good reason to stick to a fake quad instead of getting an actual quad. Other than that, seems like a decent build for MadVR and some light gaming.
ilovejedd is offline
post #11 of 16 Old 08-15-2014, 11:23 PM - Thread Starter
Liked: 0
When I talked to the guy about what I wanted to do, I did say light gaming because I didn't want to be limited in the future. More than likely, it will only be used for wmc and Internet. What is MadVR? Yes, just Ota tv signal. I would rather spend much less, but I would rather have overkill than not enough. Thanks for all the replies!
jtevis is offline
post #12 of 16 Old 08-16-2014, 04:10 AM
Quoted: 71 Post(s)
Liked: 37
IMO future proofing never works, new things will always be better. I would too scale back on the 840 Pro, also I think there are cheaper (and slower) RAMs out there. RAM speed is not needed with a dedicated GPU.
MadVR is a high quality renderer, and currently there are no GPUs capable of running at the max (don't even start thinking about achieving "highest quality possible" ). It's also quite advanced and doesn't work with WMC. Unless you want to venture into the high quality picture videophile territory, I would not recommend it.
If anything, I would improve the CPU to 4 core i5, and ditch expensive RAM, SSD, maybe GPU at your discretion (and I absolutely love the 750Ti, simply the best GPU at the moment. That is if nVidia would support 88.2 khz playback. Grr). For general video usage, the HD 4600 iGPU should be plenty.
StinDaWg and ilovejedd like this.
post #13 of 16 Old 08-17-2014, 02:03 AM
bob2300NX's Avatar
Above posters are on the $. You wont notice a difference between samsung 840 pro and MX100 at least nothing noticable. But an i5 vs i3 could definitely come in handy. Basically compromise where you can to get the i5, its worth it.
bob2300NX is offline
post #14 of 16 Old 08-18-2014, 06:04 PM - Thread Starter
Liked: 0
OK, changed out for the mx100 and i5 4690k, is it all good now? Is that the best and most reliable tuner? Anyway to spend the 1030.00 better? Thanks again for the help
jtevis is offline
post #15 of 16 Old 08-18-2014, 07:53 PM - Thread Starter
Liked: 0
Wow, actually 1130 with hvr 2250 w/out win 7. If I understand you guys, I don't need a graphics card at all with that cpu? What would be the best ram? I think I have made the other cuts suggested.
jtevis is offline
post #16 of 16 Old 08-19-2014, 05:14 AM
Quoted: 71 Post(s)
Liked: 37
Hmm RAM prices are very different here, so I'm afraid I can't help with that (and I'm not even sure anymore yours is expensive). GPU is not needed if you don't want to game with serious 3D games. HD 4600 is quite strong for 2D playback and HW accelerated rendering.
Reply Home Theater Computers
