Intel Graphics Quantization Selection Peristent Problem - AVS Forum | Home Theater Discussions And Reviews
Old 08-18-2014, 04:14 AM - Thread Starter
InstantEulogy's Avatar
Quoted: 20 Post(s)
Liked: 25
Hello Guys and Gals,
I've read up on some other forums and threads about this issue and wanted to share what I know so far. I have an Intel i7 with an AMD 6770 working in tandem on my laptop. The Intel Graphics Control Pantel controls the HDMI port settings. I connect a monitor to my receiver that definitely looks best in Full RGB, or full quantization mode, as opposed to Limited as my selection in the Intel Graphics Control Panel. The problem for me, is that when I select Full, it only saves my selection until the computer is turned off or standby or the resolution changes and also when I have to okay something as an administrator on the computer. The monitor immediately looks darker, and I have triple checked that the Intel Graphics Control Panel reverts itself to the "Limited" setting. Very annoying.
I tried the registry hack where you add the enable full rgb dword and that just took away my option for having limited or full quantization, and just made it get stuck on Limited until I removed the DWORD.
I have also tried creating a custom resolution using 1920x1080, 60Hz refresh, 32 Bit Depth and CVT-RB and CVT timings, but unfortunately those settings don't work for me either.
Is there anything else that I can do for this laptop that will get the quantization setting to stick? I am using the latest publicly available drivers for the Intel Graphics and AMD card combo from Leshcat. Until then, every time my screen flickers on or off I have to open the control panel and navigate to montior/tv settings and change it to "Full" every time. At least I have verified that it does properly go into Full mode...the settings just don't stick.
InstantEulogy is offline
Old 09-12-2014, 09:13 AM
Liked: 0
Could you provide a few details about your system?
1. Make / model of laptop
2. Graphics driver versions
3. Operating system
4. Monitor make and model
Also, are you clicking "Apply" after you select "Full Range"?
zonzin is offline
Old 09-12-2014, 04:21 PM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 397
There is a dedicated thread about this Intel issue. Do a search.
Foxbat121 is online now
