9.2 Surround in HTPC - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By Slosh
post #1 of 9 Old 08-23-2014, 02:06 AM - Thread Starter
iwanrs's Avatar
Quoted: 48 Post(s)
I just upgraded my HT speakers from 7.2 to 9.2 Surround system by adding 2 Front Height Speakers.
I have set the speakers configuration at Denon AVR-4520CI to 9.2 speakers setting, and tested fine.
But in my HTPC control panel sound setting, I can only get the 7.2 system maximum, no 9.2 setting.
My HTPC running Windows 7 64bit with MSI R7850 Graphic Card.
Connections are all the way via HDMI.
How can I get 9.2 surround sound out of my HTPC ?
iwanrs is offline
post #2 of 9 Old 08-23-2014, 05:09 AM
balky's Avatar
Quoted: 227 Post(s)
Liked: 131
I think the source material has to be 9.2 surround sound as well... and must be bit-streamed to the AVR...
balky is online now
post #3 of 9 Old 08-23-2014, 05:16 AM
balky's Avatar
Quoted: 227 Post(s)
Liked: 131
On a second thought, if windows is getting the right EDID from your Denon AVR, I think it should be possible to set windows for 9.2 surround sound, unless there is a EDID bug or something... or maybe an HDMI limitation... IDK...
balky is online now
post #4 of 9 Old 08-23-2014, 06:15 AM
Slosh's Avatar
Quoted: 51 Post(s)
Liked: 33
There is no 9.2 discrete channels format. Your receiver is using DSP to create 9.2 channels out of 5.1 and 7.1 sources.
|Tch0rT| likes this.
Slosh is offline
post #5 of 9 Old 08-23-2014, 06:18 AM - Thread Starter
iwanrs's Avatar
Quoted: 48 Post(s)
There must be a crucial setting I miss, in HTPC ?
Can it be a limitation of the Graphic Card's audio processor?
My HTPC has Intel Haswell processor.
iwanrs is offline
post #6 of 9 Old 08-23-2014, 05:27 PM
bryansj's Avatar
Quoted: 1130 Post(s)
Liked: 560
For 9.2 it is up to your receiver to process it correctly. You would just bitstream from the source material and the receiver will expand the 5.1 or 7.1 to 9.2. You'll need to read your receiver's manual to figure out the surround modes that support 9.2. I personally don't care much for the special formats and the only one I uses is to expand the TV stereo signals to Dolby PLx (or whatever it is called) to get 7.1.
bryansj is offline
post #7 of 9 Old 08-24-2014, 01:08 AM
aftcomet's Avatar
Quoted: 53 Post(s)
AFAIK there isn't anything consumer based that is master in 9.2. 7.1 is the highest I've seen native audio go before extra processing is introduced.
I would assume that would be done by your AVR. So set Windows output to 7.1 and have AVR upmix to 9.2.
aftcomet is offline
post #8 of 9 Old 08-25-2014, 02:54 PM
ES_Revenge's Avatar
Quoted: 410 Post(s)
Liked: 133
You can't. As someone posted above, there's no discrete 9.2 (or even 9.1) format at the moment and the receiver more than likely does not accept 9.2 PCM, which is why it is not in the EDID and why Windows (which might be capable) won't output such a format to your receiver.
Instead you need to set it up for 7.1 and then engage PL-IIz or proprietary 9.2 encoding on your receiver, to get 9.2 audio produced.
ES_Revenge is offline
post #9 of 9 Old 08-26-2014, 05:02 PM - Thread Starter
iwanrs's Avatar
Quoted: 48 Post(s)
Thumbs up
Thanks all the replies.
I know now: The trick is in AV Receiver.
iwanrs is offline
Reply Home Theater Computers
