Silverlight - All videos stuttering (Live and On Demand) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 08-26-2014, 01:45 PM - Thread Starter
xreyuk's Avatar
Hi Guys,
After a bit of help.
We use Silverlight here in the UK to watch Sky Go, BT Sport, and Amazon Prime Instant. There is no other option on any of those services to use flash instead (not even on Amazon Prime Instant).
I have a Windows 7 x64 HTPC with an Intel Core i5 3570K, 4GB RAM, 120GB SSD, and 500GB HDD.
I have tried various versions of silverlight 5 (cannot use anything older than 5 as the websites won't allow it). I've tried Chrome, Firefox and IE. I've tried disabling application storage, and disabling hardware acceleration in Silverlight in all browsers.
However, despite the above, I cannot get ANY silverlight video to play without a sort of 'micro stutter'. It's not massive, however, it is definitely not smooth video.
I can watch the websites on my less powerful Macbook without problem.
Can anyone suggest where I might start/if there are any fixes?
xreyuk is offline
post #2 of 14 Old 08-26-2014, 11:11 PM
ilovejedd's Avatar
Quoted: 76 Post(s)
Liked: 67
That's been an issue with Netflix on Silverlight from long ago. I don't think Microsoft ever fixed it.
ilovejedd is offline
post #3 of 14 Old 08-27-2014, 01:45 PM - Thread Starter
xreyuk's Avatar
Ahh okay
Just luck of the draw as to whether it will work smoothly or not?
xreyuk is offline
post #4 of 14 Old 08-28-2014, 12:22 AM
ilovejedd's Avatar
Quoted: 76 Post(s)
Liked: 67
Actually, I believe the more sensitive types have mentioned video is never smooth. I guess it's just luck of the draw whether you notice it or not.
post #5 of 14 Old 08-28-2014, 10:12 AM - Thread Starter
xreyuk's Avatar
Ahh no problem. Definitely less noticeable in IE (of all things) but guess I'll have to put up with it
xreyuk is offline
post #6 of 14 Old 08-28-2014, 11:09 AM
mrfattbill's Avatar
Quoted: 91 Post(s)
Liked: 89
Save your current personalized settings and then enable "Aero"....as strange as it sounds, 2D acceleration is not enabled in Win7 if Aero is not also enabled....I was having terrible stuttering and tearing issues until I did this.
Bill
mrfattbill is offline
post #7 of 14 Old 08-28-2014, 11:38 AM - Thread Starter
xreyuk's Avatar
Bill
Thanks, I do have aero already enabled.
Any other suggestions are welcome
xreyuk is offline
post #8 of 14 Old 08-28-2014, 11:59 AM
mrfattbill's Avatar
Quoted: 91 Post(s)
Liked: 89
Have you gone as far as having Windows select the best options: Right click My Computer -> Properties -> Advanced System Settings ->Advanced tab-> Performance and then settings.
Bill
post #9 of 14 Old 08-29-2014, 09:40 AM - Thread Starter
xreyuk's Avatar
Bill
No I hadn't
Just enable everything?
xreyuk is offline
post #10 of 14 Old 08-29-2014, 12:44 PM
mrfattbill's Avatar
Quoted: 91 Post(s)
Liked: 89
No I hadn't
I would give it a shot at least.
Bill
post #11 of 14 Old 08-29-2014, 01:04 PM - Thread Starter
xreyuk's Avatar
No difference unfortunately
xreyuk is offline
post #12 of 14 Old 08-29-2014, 01:12 PM
SteelWill's Avatar
Quoted: 79 Post(s)
Liked: 38
Try HTML5 in Chrome? Here are the Linux instructions, not sure what more/less you have to do in Windows.
http://www.omgubuntu.co.uk/2014/08/n...upport-plugins
And yes, Netflix/Silverlight stutter goes back for forever.
SteelWill is offline
post #13 of 14 Old 08-29-2014, 01:14 PM - Thread Starter
xreyuk's Avatar
Hi,
Unfortunately Im not using Netflix, I'm using Sky Go, BT Sport and Amazon Prime Instant. There's no option to use HTML5 with these providers.
xreyuk is offline
post #14 of 14 Old 08-29-2014, 02:00 PM
SteelWill's Avatar
Quoted: 79 Post(s)
Liked: 38
Ah, sorry for glossing over. Hopefully both Silverlight and Flash get dropped en masse for HTML5 once it matures a bit more.
Reply Home Theater Computers
