HD 5450 1GB Optimal Settings? - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By Veeper
  • 1 Post By kevin g.
post #1 of 25 Old 08-27-2014, 06:57 PM - Thread Starter
kevin g.'s Avatar
Quoted: 334 Post(s)
Liked: 145
Hey guys,
I recently cut the cord, and my main streaming rig is an older P4 upgraded to W7, with an added WD Black 1TB HDD. The original Video Card was an AMD X300. It was dragging/hogging resources while streaming online HD, and XBMC content.
I bought a Sapphire HD 5450 a while back, and never really got it up and running correctly.
Later I added an HP N40L server to my network, and stole the 5450 for it. (original configuration for the N40L is no audio and onboard VGA). I found I was not using the Microserver as a display device, and was utilizing the headless capabilities more. So, back the 5450 went, in to my P4 desktop. I have downloaded Catalyst 14.4 and installed.
I am still getting 80-90% CPU usage while streaming on this machine. I have gone through all the settings, and really see nothing to optimize performance. I am also running the VGA, as it is a cleaner picture. The HDMI picture is offset, with no way to correct overscan completely. Colors are over saturated and blurry/not natural looking. (these reasons are why I gave up on it in the first place...)
So, as always, I come here for advice and guidance. Can someone give me some input on optimal performance, and maybe a way to tweak the HDMI output to get a better display?
Edit:
Web pages/print looks atrocious on the HDMI Input. Photos and web content pictures are grainy and harsh.
Also,when I leave the HDMI input, to watch ordinary TV...and come back to the correct HDMI input, I receive a blue screen (TV blank, not BSOD....) and "No Signal" message.
Thanks in advance
"Once you learn good English...Can't nobody take it away!"
Xbox LIVE Gamertag: KEVIN G 40
kevin g. is offline
post #2 of 25 Old 08-28-2014, 07:37 AM
ES_Revenge's Avatar
Quoted: 419 Post(s)
Liked: 138
Doesn't make any sense that VGA would be better than DVI/HDMI as the former requires a D/A and then A/D conversion (assuming you have a digital display like an LCD).
Did you try turning off GPU scaling and setting the overscan to 0% over HDMI/DVI?
As for the high CPU during "streaming", what file types are you streaming, what program are you using to play them, and where are they being streamed from? A local NAS or sever or are you talking about through intarwebs?
ES_Revenge is online now
post #3 of 25 Old 08-28-2014, 08:37 AM - Thread Starter
kevin g.'s Avatar
Quoted: 334 Post(s)
Liked: 145
I agree, but I am definitely seeing a FAR superior picture over VGA. Set is an older 720 LCD. I tried every setting imaginable in the console. All de-interlacing has been negated. Overscan set at "0" is actually too small. (720p setting on AMD console) If I "zoom" to fill the screen, I find that it is shifted up, as the minimize/close boxes in windows, and menus are kind of cut off.
I do not get PC resolution options sent back to the AMD console when viewing via HDMI.
Streaming issues are via the interwebs. XBMC, and network TV sites, so my wife can catch up on shows. Flash sites...(like TWITCH) chew up CPU, and I was hoping to offload some of that processing to the GPU.
Last night, after posting, I had multiple BSOD crashes when starting XBMC. I am in the process of uninstalling/re-installing. Not having much faith, though. I have seen the picture quality issue the last 3 times I installed.
Honestly, that was the reason I had no qualms installing the 5450 on my server and going back to the stock card. I felt that if I was utilizing VGA on an upgraded card...why upgrade?
kevin g. is offline
post #4 of 25 Old 08-29-2014, 09:44 AM
ES_Revenge's Avatar
Quoted: 419 Post(s)
Liked: 138
Hmm, if you're at 0% overscan and the image is too small to fill the screen, it sounds like your TV is underscanning. Is there an option on the TV to display "full-pixel" or 1:1 mapping? If not you can use the overscan slider but I'd recommend you create a custom resolution instead in Catalyst. I'm not sure that will work for VGA but in HDMI it should work as the TV should still get a "720p" signal but the desktop will fit the screen. Using custom res is also clearer because IIRC if you use the scaling options instead (i.e. the overscan slider) it makes the image blurry.
Also flash is a bit crap, but there is an option to enable hardware acceleration--right click on the video and make sure it's selected (though it probably is already). It should be using HA but perhaps there's some reason it's not able to.
As for the local files and XBMC that should definitely be able to use DXVA. I'm really not that familiar with XBMC since I don't use it but check out this link and see if it's enabled and working:
http://wiki.xbmc.org/index.php?title...MC_for_Windows
post #5 of 25 Old 08-29-2014, 03:57 PM - Thread Starter
kevin g.'s Avatar
Quoted: 334 Post(s)
Liked: 145
Thanks ES,
I don't see an option in Catalyst for custom resolutions. I will look some more. Hardware acceleration is enabled. I have also found a way to do it "in browser"...not sure it will help. The scaling is in proportion, but everything is moved up a few pixels, as well as a bit small. (So, when enlarged the corners don't exactly match up.) I have an "auto adjust" in VGA, via the TV menu, but nothing like that in HDMI. TV reports natural resolution in Catalyst as 1366 x 768.
I just enabled DXVA in XBMC, not sure if it made a difference yet.
kevin g. is offline
post #6 of 25 Old 08-29-2014, 04:20 PM
ES_Revenge's Avatar
Quoted: 419 Post(s)
Liked: 138
Yeah the auto adjust for VGA is seen on nearly all digtal displays when connected to VGA. It adjusts the phase and whatever and makes the image look clear--turns out almost like an autofocus of a camera making the image clear.
HDMI won't have that, as you've seen as it's already a digital format. What is the native resolution of the TV? Is it 1280x720 or 1366x768? I would check the manual to be sure.
What you need to do to make a custom resolution is the following. Connect the TV via DVI/HDMI at the desktop. If there's any options in the TV's menu for "full pixel" or "1:1" mapping or adjusting the zoom, try those first to see if you get the image to fill the screen properly. If not, continue...
Right click on desktop and open CCC; on the left frame select "My Digital Flat Panels" then from that list select "Scaling Options". Make sure the slider is at 0% and that the box regarding scaling is unchecked. Then go to "HDTV Support". Make sure all the resolutions your TV will accept are checked in the first list. Click "Apply" if necessary. Then in the lower box select the "720p Standard" resolution and click "Apply Format". Once you do that you should be able to click "Add". When you do that it will take you to a screen you can adjust until the edges of the screen are best fit to your TV. I would keep the aspect ratio locked when doing this to avoid stretching/distorted image issues when playing videos.
Once you do that you will see that you've just created a 720p custom resolution in the lower drop down box and you should see that the desktop now fits your screen properly and it should look very clear--just as if you were using a computer monitor.
Try that^ out and see how it goes.
post #7 of 25 Old 08-29-2014, 05:08 PM - Thread Starter
kevin g.'s Avatar
Quoted: 334 Post(s)
Liked: 145
Great! Thanks for the walkthrough. I will try those steps and report back...
kevin g. is offline
post #8 of 25 Old 08-30-2014, 09:52 AM - Thread Starter
kevin g.'s Avatar
Quoted: 334 Post(s)
Liked: 145
Well...
Attempted all the steps.
First, there is no 1:1 mapping on the display. Second, I was mistaken earlier, setting the overscan to "0" put the image much larger than the screen. (I was using the center of the scale, setup automatically by CCC, as a zero reference point...when, in actuality, the far right is "0" and the far left is 15%. )
Adding in the custom resolutions as described brought the screen size back down, but showed less resolution. (11-something x 688...) And I had the same issues. The top of the screen is cut off, and the bottom has black banding. Typing this, letters are blurred and "pinched"...not as clear.
I am also still having the problem of input switching. If I leave the HDMI2 input, to say...watch TV, I cannot come back to the PC screen. All I get is the "No Signal" blue screen. I will try the HDMI1 input, and see if there is any difference.
I am certain that my wife does not see any of these issues, all she wants is to watch her shows. (I am the only one doing any PC/email/forum-hopping on this display) I'm thinking I either leave it alone, or go back to VGA.
One question I have is, am I introducing any more CPU usage, by going back to VGA, vs. direct HDMI?
Thanks for the assist...
kevin g. is offline
post #9 of 25 Old 08-30-2014, 11:06 AM
mdavej's Avatar
Quoted: 2277 Post(s)
Liked: 992
We know the 5450 can easily do 720p and 1080p over HDMI. So I think the issue lies with your TV. Can you post the make/model and a link to the manaual? Then again, if VGA works, just stick with it. I ran 1080p VGA for years, and it looked identical to HDMI. No extra burden on the card or CPU at all. The only reason I eventually switched to HDMI is because my 20 year old AVR finally croaked, and I got a new one with HDMI.
mdavej is online now
post #10 of 25 Old 08-30-2014, 11:29 AM - Thread Starter
kevin g.'s Avatar
Quoted: 334 Post(s)
Liked: 145
I agree with this. The image looked fine on my projector, when the 5450 was in my Microserver. The only thing that gives me hesitation, is that I have no other HDMI source issues on this set. I have run HDMI from my 360 to this set, with PC resolutions (separately, and through my Onkyo 818...), also the Microserver was set up on this display with the card in question, as well as it being my secondary display for my Xbox One, driven through the 818.
http://support.vizio.com/product/vw37lhdtv10a
I was thinking of going back to the VGA, but again, Why even utilize the card here? I am not sure I gained much, if any, decrease in the load to the CPU...
kevin g. is offline
post #11 of 25 Old 08-30-2014, 12:02 PM
ES_Revenge's Avatar
Quoted: 419 Post(s)
Liked: 138
When you setup the custom res, was the overscan slider at 0% and the scaling option checkbox unchecked? If so, not sure why you're getting the blurry output; in that case yeah just go back to VGA if VGA is working fine. There's not going to be any more CPU use with VGA output--the card's DAC takes care of that on the output side and the TV's ADC/scan converter takes care of it on the input side. Only downside I can see is possibly more input lag, but that's about it.
post #12 of 25 Old 08-30-2014, 12:31 PM - Thread Starter
kevin g.'s Avatar
Quoted: 334 Post(s)
Liked: 145
Yeah...I followed your instructions to the letter, double checking before I moved on. I'm going to try some screen shots...to determine if there is actually a difference, or if the TV is truly the culprit.
kevin g. is offline
post #13 of 25 Old 08-30-2014, 01:51 PM
mdavej's Avatar
Liked: 992
So, looking at the manual, the native resolution of your screen is 1366x768. 720p with no overscan is 1280x720. So when you feed it that lower res over HDMI or mess with the scaling in your video card, it's going to get upscaled to native and probably not look as good. Better to feed it exactly 1366x768 over VGA, IMO. Also that TV is 7 years old and probably not as good at scaling as later models. If/when you ever get a newer or 1080p TV, it will look much better over HDMI. So I'd live with VGA on that TV.
Furthermore, if that res plays smoothly from your onboard video, then I agree the card is unnecessary. Take it out if you want to reduce the heat and power consumption.
post #14 of 25 Old 08-30-2014, 02:54 PM - Thread Starter
kevin g.'s Avatar
Quoted: 334 Post(s)
Liked: 145
Yes, that is the native resolution reported. I agree on the upgrade, but it is just a bedroom set, and not the main display, so it will probably stay until it dies.
I am not using the onboard video, no matter what transpires. The machine came with a Radeon X300, (as mentioned above). It is obviously older as well. So, either that goes back in, or I stay with the 5450. Unfortunately no new equipment is slated until I can get back to the workforce.
Is this card putting more stress on my system? I was under the assumption that it was relieving the overworked CPU.
Thanks to both of you, for all your help. I will switch back to VGA, and hold out until we can afford extra.
kevin g. is offline
post #15 of 25 Old 02-07-2015, 09:36 AM
doubleJ's Avatar
Hello...
I thought I would chime in, on this, as I just experienced a similar issue (and fixed it).
1080p/60 was bigger than the screen and I had to underscan, for it to fit.
I never thought the text looked as crisp, as it should (not terrible, just not clean).
In Catalyst Control Center, I have an option for Pixel Format.
It defaulted to YCbCr 4:4:4.
I changed it to RGB PC Standard and everything shaped right up.
JJ
doubleJ is offline
post #16 of 25 Old 02-07-2015, 12:15 PM - Thread Starter
kevin g.'s Avatar
Quoted: 334 Post(s)
Liked: 145
Originally Posted by doubleJ View Post
Hello...
JJ
Thank you for this. I never thought of trying that. I will give it a shot. I have to dig out another HDMI cable...
kevin g. is offline
post #17 of 25 Old 02-08-2015, 09:10 AM
ES_Revenge's Avatar
Quoted: 419 Post(s)
Liked: 138
Hello...
What you're seeing is the difference between using scaling and using a custom res. When you use scaling that's what happens because it's essentially "crushing" pixels into one another to the percentage you set on the scan slider. When you use a custom res OTOH (to correct overscan at least), it's still outputting the same resolution (like 720p or 1080p) to the TV but it's like it frames the desktop into the resolution you set "within" the main output resolution. This way the text and everything remains perfectly clear. I'm not sure exactly how it works for playing back videos (like BD for example) that are actually higher resolution, but it also seems to work better and look sharper with custom res than with scaling.
My older TV would overscan and so this is how I discovered the above--when I set a custom res it was always nice and clear/sharp so that's how I used it for the years I had that TV. Most modern TVs either allow for or default to 1:1, so this usually isn't a problem anymore.
JJ
It seems like you've either inadvertently changed some other setting in the driver by doing that or (what I think is more likely) is your TV stops overscanning and displays 1:1 automatically when it sees a PC/RGB signal as opposed to a video timing. Either way good you got it fixed.
post #18 of 25 Old 02-09-2015, 07:27 AM
TornadoTJ's Avatar
Quoted: 1723 Post(s)
Liked: 539
Make sure you turn off all the processing junk in CCC. Under video, click Color, then Advanced Video Color, and uncheck all that stuff. You may need to be set to Limited dynamic range too, this will depend on your display and the display settings. Next click Quality, and uncheck all that stuff under Video Quality. (edge enhancement, de-noice, dynamic contrast). Look under Global Video Quality, and this should be all unchecked too.
Sine I upgraded my HTPCs to i3's a while back, I had some 5450s laying around. That's what I'm using to type this on, on my two 1920x1080 displays.
TornadoTJ is offline
post #19 of 25 Old 02-12-2015, 05:25 AM
Veeper's Avatar
I'm not sure if the OP is still checking this thread or not, but for what it's worth, that model of Vizio is UNABLE to feed the LCD a proper resolution via HDMI. The max resolution via HDMI on that particular model is 1024x768. Only VGA will allow the correct native resolution of 1366x768.
The fault is Vizio's and ultimately then is your display, not the CCC or AMD chipset on that particular card. This is also why, when connected via HDMI, your overscan settings appear to blow the picture wider than the TV's display area. The card is doing what you're telling it to do, and compensating beyond the current resolution of 1024x768.
Veeper is offline
post #20 of 25 Old 02-12-2015, 08:38 AM - Thread Starter
kevin g.'s Avatar
Quoted: 334 Post(s)
Liked: 145
I am following, and although what you are saying makes sense...where are you getting this information? Because, I previously had many other HD sources hooked up via HDMI to this set, and have never seen any video distortion. Is this only cropping up under PC resolutions?
kevin g. is offline
post #21 of 25 Old 02-12-2015, 10:37 AM
Veeper's Avatar
Thanks for the reply. Unless I'm mistaken, that model is the same as the VX37L (The W denotes the black "Walmart" edition of the set.) There used to be extensive information on this issue all over AVS, and the only reason I know this is because I had one and could never get a PC to display 1366x768 via HDMI. IIRC, someone from Vizio eventually chimed in on either a support ticket or through an AVS member email. I'll poke around a bit and see if I can find it.
My Vizio VX37L is at my parent's house now, and to this day, the only way to use HTPC with a decent resolution is via the VGA input.
Again, I'll poke around a bit and see if I can find the relevant information for you.
Not your specific model:
Mini + Vizio L32 + HDMI
Another discussion starting here:
Vizio 37" (VX37L) LCD HDTV Official Thread
Referencing the limitation:
Veeper is offline
post #22 of 25 Old 02-12-2015, 10:52 AM - Thread Starter
kevin g.'s Avatar
Quoted: 334 Post(s)
Liked: 145
Yeah, I followed the dedicated thread for a while, but at that time I did not have my PC connected, and I also lost interest. I remember it being the "Walmart" edition, with a few less features and other minor differences. I have ultimately been very satisfied, as it has been rock solid. (Not so, for other much more expensive brands that have troubled me).
Thanks for the info, I will stick with VGA and analog.
kevin g. is offline
post #23 of 25 Old 02-12-2015, 11:06 AM
Veeper's Avatar
I agree, it's a great set, and I considered the Walmart version for the fact it was black and the remote was only slightly different (IIRC); however I actually ended up with the silver one because NewEgg was running a special.
Funny thing - I actually only stumbled into this thread by chance. I had a Dell Zino HTPC that had a 5450 in it at one time, and I was like, "Oh hey neat! I wonder how the 5450 is cutting it these days. Great chip that is!"
Have a great week/weekend!
kevin g. likes this.
Veeper is offline
post #24 of 25 Old 02-12-2015, 11:09 AM
TornadoTJ's Avatar
Liked: 539
They still get recommended even.
post #25 of 25 Old 02-12-2015, 11:58 AM - Thread Starter
kevin g.'s Avatar
Quoted: 334 Post(s)
Liked: 145
I do remember that now...I wanted the black set over the silver. Funny how the memories of that stuff goes away after a few years.
I am loving the extra boost the 5450 is giving my aged C2D. (a new-to-me machine that TornadoTJ and a couple others on the boards helped me with...)
Veeper likes this.
kevin g. is offline
Reply Home Theater Computers
