i3 or i5 NUC - AVS Forum
post #1 of 8 Old 09-13-2014, 10:10 AM - Thread Starter
Tyborg's Avatar
i3 or i5 NUC
I am planning to setup a couple NUCs at my house in lieu of extenders. I will be playing bluray content over the network and watching 1080i broadcast content. Almost no network streaming from the likes of Hulu, Netflix, Vudu, etc. I would like to be able to throw content at software based chromecast or airplay implentations on the NUC. No 3D content. That being said is there any benefit to using the i5 with HD5000 graphics over the i3 HD4400 in the latest Haswell NUCs?
Tyborg is offline
post #2 of 8 Old 09-13-2014, 10:13 AM
assassin's Avatar
Quoted: 50 Post(s)
Liked: 241
No. For what you describe i3 is plenty. Many of us use bluray ripped to mkv. I can attest that the i3 nuc can handle that with aplomb.
assassin is offline
post #3 of 8 Old 09-13-2014, 10:21 AM - Thread Starter
Tyborg's Avatar
Thanks for the response. I should mention only gaming would be NES type emulators that I am well aware it can handle. Any benefit for deinterlacing content on the HD 5000? I'm planning on mainly hardware deinterlacing and no madVR or software implementations for decoding and filters.
Tyborg is offline
post #4 of 8 Old 09-13-2014, 10:51 AM
AVS Club Gold
renethx's Avatar
Quoted: 239 Post(s)
Liked: 387
HD 4400 (and even vanilla HD) is enough for deinterlacing. Extra EUs of HD 5000 may be good for light gaming.
renethx is offline
post #5 of 8 Old 09-13-2014, 10:58 AM
Ou8thisSN's Avatar
Quoted: 55 Post(s)
if you havent bought it yet, you may as well just wait for the new Nucs to launch this January. You'll either get better gaming performance at the same price or pick up the haswell i3 nuc for cheaper in 3 months.
Ou8thisSN is offline
post #6 of 8 Old 09-13-2014, 10:58 AM
Gurba's Avatar
Quoted: 113 Post(s)
Liked: 45
With a Crystal HD decoder card you can decode 1080p With an old dual core 2.
Gurba is offline
post #7 of 8 Old 09-13-2014, 11:23 AM - Thread Starter
Tyborg's Avatar
Thanks, I think I'll just go with i3 then.
Thanks I had considered this. I haven't seen much price drop on the previous models so its not really worth the wait and the pep in graphics performance isn't something I will really need. I need to get started on these since I won't have much time after the holidays to set them up. At least if I get them now I will be able to tinker over the holidays to get them ready for use next year.
I wasn't aware of this card, but will be using that slot for my ssd and I'm feeling pretty comfortable that the i3 can pull the duties needed.
Tyborg is offline
post #8 of 8 Old 09-13-2014, 06:02 PM
AVS Club Gold
renethx's Avatar
Quoted: 239 Post(s)
Liked: 387
This is just for an older GPU that lacks a proper hardware decoder. Intel QSV decoder (implemented in all recent Intel GPUs) is superior, it can decode even 4K H.264 up to 150fps.
renethx is offline
Reply Home Theater Computers
User Tag List
