4k UHD Graphic Card - AVS | Home Theater Discussions And Reviews
Old 09-19-2014, 10:36 AM - Thread Starter
iwanrs's Avatar
Quoted: 34 Post(s)
4k UHD Graphic Card
I have upgraded my projector to Sony VPL-VW1100ES 4K projector.
My HTPC :
Motherboard ASUS SABERTOOTH Z87 LGA 1150 Intel Z87 HDMI SATA 6Gb/s USB 3.0 ATX Intel
Graphic Card: MSI R7850, 2GB DDR5, AMD Radeon
AV Receiver : DENON AVR 4520
Questions:
1. Can my current MSI Graphic Card support 4K (3840 x 2160) resolution? I check at Display Resolution the highest resolution is 1920 x 1080 only.
2. Should I replaced my MSI GC to a 4K capable GC?
If yes, what is the best card I can get with the length not longer than 9", for movies/Video watching only, no Games at all.
THANKS.
iwanrs is offline
Old 09-19-2014, 10:58 AM
NNate's Avatar
Quoted: 24 Post(s)
A similar question: Intel NUC and 4k resolution
TLDR: Wait until HDMI 2.0 supporting cards are release late this year, early next.
NNate is offline
Old 09-19-2014, 03:40 PM
Nevcairiel's Avatar
Quoted: 36 Post(s)
Liked: 129
The NVIDIA GTX 970 and 980 feature full HDMI 2.0. Those cards may be a tad bit too expensive for pure HTPC duties though, but there should be a GTX 960 soon, which might be in a better position.
MKANET likes this.
Nevcairiel is offline
Old 09-19-2014, 07:33 PM
lespurgeon's Avatar
Liked: 43
7850 should be fine for video (not gaming). May have to use DP, as DVI and HDMI may not have enough bandwidth. It could take some setup work to get it all working right. The 13.12 driver was supposed to work. The new GTX 970 is the only choice that brings new technology (HDMI 2.0).
lespurgeon is offline
Old 09-19-2014, 07:40 PM
lespurgeon's Avatar
Liked: 43
Old 09-20-2014, 12:59 AM - Thread Starter
iwanrs's Avatar
Quoted: 34 Post(s)
It seem the options are not much at this time, may be too early for 4K HTPC?
iwanrs is offline
Old 09-28-2014, 04:07 PM
blee0120's Avatar
Quoted: 162 Post(s)
Liked: 81
So, with all the different test done so far with these cards. Are there any reason to pass these up for 4k gaming? 2-way sli on the gets 980 gives you 40fps+ and the sli 970 gives you above 30fps+ for the majority of 4k gaming. I would probably do 2 gtx 980s or 3 gtx 970s. Any reasons to not buy for gaming?
blee0120 is online now
Old 09-29-2014, 02:30 PM
Nevcairiel's Avatar
Quoted: 36 Post(s)
Liked: 129
30 or 40 fps wouldn't satisfy me for gaming, and making your display scale by using a lower resolution is also terrible. In short, wouldn't buy a 4K screen for gaming for at least another GPU generation. By that time, we'll also have DP 1.3 with all the bandwidth we need, without crappy MST.
Old 09-29-2014, 05:23 PM
ES_Revenge's Avatar
Quoted: 266 Post(s)
Liked: 96
^This. It does depend on the game you're playing as 30fps is the "playable" number but being locked at 30 kinda sucks if your card can play higher. For modern PC games and gaming I think more people are expecting higher though, esp. on games where you've got fast-paced action going on.
Remember that most console gaming used to be 30fps, pretty much universally...wasn't until 7th gen consoles that faster frame rates became the norm. So 30 fps is not at all terrible, provided there's low input lag on the TV (speaking of that, how are current 4k TVs in that regard?). 60fps does provide a better gaming experience though.
There aren't really any single cards that can get near to 60fps @ 4K in modern games though. As someone pointed out above even in SLi you're struggling getting there in some games! :O If you've got V-Sync on, you're down to 30fps anyway. Of course this is where G-Sync comes in. BUT... How many TV/projectors support G-Sync? LOL.
I don't see the need for 4K yet either because:
-For video there's not much content; and, it's really only necessary if you have a 70"+ screen IMO.
-For gaming you need a very fast card or SLi/Crossfire, but unless your monitor/TV/projector supports DisplayPort you're going to need HDMI 2.0. Also...what I said about G-Sync. So that leaves your only real option as the GTX 970 or GTX 980. $400+ cards right there. But again for CE gear, I don't think anything supports G-Sync yet (?).
-As mentioned, not gaming in native res. is a bad idea.
Net result? 4K gaming is not really ready for primetime...Unless you have a lot of $$$ to spend. Best to wait a few years.
OP of course does not mean for gaming. For video, the 7850 will output that high for HDMI but at a max of 30Hz. However the 7850 is not going to be able to do HW decode of 4K content either, so hopefully OP has a fast CPU. I'd stick with the 7850, wait about 6-8 months when cards start having HDMI 2.0 std. along with 4K HW decoding capabilities, then upgrade.
ES_Revenge is offline
Old 10-26-2014, 09:23 PM - Thread Starter
iwanrs's Avatar
Quoted: 34 Post(s)
It is more than one month ago since I posted this Thread.
Now is near year-end shopping season.
Is there any NEW development regarding 4K Capable Graphic Card?
Latest technology and more reasonable price, may be?
My usage is mainly for 4K-Video, not Gaming.
Low profile possible.
iwanrs is offline
Old 10-26-2014, 09:32 PM
DRaven72's Avatar
Quoted: 49 Post(s)
Liked: 69
So basically you are looking at lower end card, around $150 that can play a true 4K signal to a 4K TV? Short answer: NO. Nothing from Nvidia on the 950/960 cards yet. Rumor is next year, AMD Febuary launch, Real 16/20nm Nvidia Maxwell late March. Could be a 950/960 slipped in there before Xmas, but I doubt it as nothing has leaked at all.
Cool Beans.
DRaven72 is offline
Old 10-26-2014, 10:45 PM
LexInVA's Avatar
Quoted: 117 Post(s)
Liked: 65
The closest you will get is the GTX 970, which is coming next month in a mini-ITX design from Gigabyte. That will retail for around $340. However, it is likely that we won't see VP9 and proper HDMI 2.0 connectivity until the next generation of GPU, so there isn't any reason to buy anything right now.
LexInVA is offline
Old 10-27-2014, 12:04 AM - Thread Starter
iwanrs's Avatar
Quoted: 34 Post(s)
Too bad, no 4K Video for Christmas & New Year.
iwanrs is offline
Old 10-27-2014, 12:52 AM
Chronoptimist's Avatar
Liked: 314
The 900 series has proper HDMI 2.0 support.
No, console gaming used to be 60 FPS, and is now 20-30 FPS for the majority of titles.
30 FPS is terrible for gaming, especially if you are playing PC games with a mouse.
Chronoptimist is offline
Old 10-27-2014, 06:37 AM
LexInVA's Avatar
Quoted: 117 Post(s)
Liked: 65
No, it doesn't seem to, despite Nvidia's claims. HDMI 2.0 connectivity is all over the place with the 900-series according to what people are experiencing with their UHDTV sets and there are signs that something isn't right. Some cards work perfectly and others won't work at all with the latest HDMI 2.0 UHDTVs, even if they are of the same GPU and basic design, but from a different vendor. Nvidia also flip-flopped their specs pages, originally posting information that implied HDMI 1.4 and then changed the pages to say HDMI 2.0. a bit after the cards went wide because I and many others called them out on the contradictory information we had been given by their advertising and presentations.
LexInVA is offline
Old 10-28-2014, 12:14 PM
ES_Revenge's Avatar
Quoted: 266 Post(s)
Liked: 96
Huh? What console games "used to be" 60FPS? Old skool consoles certainly aren't. NTSC was essentially 30Hz so definitely no SD consoles were. Well I mean they could have ran faster but there would be no point.
With newer consoles, I remember when F-Zero GX on Game Cube came out, 60FPS was a huge thing and it was one of the only games that could do it on GC (and one of the few for all consoles at the time). However in the case of F-Zero GX you had to have both the rare GC component cable, and you had to power your GC on in a special way in order to get progressive scan to turn on.
There were a limited number that could do it on Dreamcast, PS2, etc... On google (a quick search), found a thread where people try to list games that were 60fps in 6th gen consoles:
http://www.neogaf.com/forum/showthread.php?t=759659
Not exactly a huge number of games, is it? Not many PS3 games can do it either... Here's another thread where people list games that are 60fps for that console:
http://www.gamefaqs.com/boards/92775...ion-3/69574012
Again just a quick search but the answers are not too forthcoming...because 60fps console gaming is not all that common and never has been.
I'm not sure how 30fps is "terrible for gaming" given the vast majority of console gaming throughout history has been well below 60fps. That would be saying that almost all videogames prior to current-day, high-end PC gaming have been "terrible" I'm not going to even bother spelling out what kind of absolute hogwash that statement is.
As for gaming with a mouse I never understood that and will never do it. I have no idea how that is "gaming" yet I know that's how many people "game" on a PC for FPS type games so whatever.
Also every major PC publication out there that tests videocard and CPU gaming performance...Tom's Hardware, Anandtech, Xbitlabs, Hardware Secrets,...and the list goes on, considers 30fps as an "acceptable" gaming framerate. They only resort to saying a given game/resolution/settings are "unplayable" on given hardware when it drops below 30fps. Yes they may like to see 60fps+ but they do not state things are unplayable or "terrible" (lol terrible ) below that.
60fps is certainly desireable but it's definitely not required and definitely doesn't mean any games not reaching such a framerate are "terrible".
Old 10-28-2014, 04:31 PM
qz3fwd's Avatar
Quoted: 215 Post(s)
Liked: 98
I was just researching UHD GPU options after pulling my Windows Machine out of storage to replace my Mac Pro tower and quickly reached the conclusion that UHD is not properly supported in the newely released Nvidia hardware and we will have to wait until the next generation. H.265 apparently will not be hardware accelerated and HDMI 2.0 is questionable........
qz3fwd is offline
Old 10-28-2014, 05:23 PM
LexInVA's Avatar
Quoted: 117 Post(s)
Liked: 65
Nvidia's Pascal should have VP9 AND HEVC in the PureVideo ASIC as well as proper HDMI 2.0 support in the GPU as it will be commonplace in the 2016 monitors and UHDTVs.
LexInVA is offline
Old 10-28-2014, 07:21 PM
speedklz's Avatar
30 fps in a game is horrible. You would be shot in an online match and you would not even know it for a second. If you can't hit at least 40 it's just no fun and 50 or above is getting better.
Rotting my brain one movie at a time!
Sony 55A3000
Sony 5100 BD
Mitsu 73837
speedklz is offline
Old 10-28-2014, 08:48 PM
kesawi's Avatar
Quoted: 28 Post(s)
Liked: 24
This is an old article but it provides a good explanation of the physiology behind human vision when it comes to different frame rates:
http://www.joz3d.net/html/fps.html
kesawi is offline
Old 12-21-2014, 06:14 PM - Thread Starter
iwanrs's Avatar
Quoted: 34 Post(s)
Is there any NEW development regarding 4k/2160p capable Graphic Cards for HTPC (movies not games) ?
New models, cheaper price may be ?
MERRY CHRISTMAS.
iwanrs is offline
Old 12-21-2014, 06:41 PM
DavidinCT's Avatar
Quoted: 119 Post(s)
Liked: 37
MERRY CHRISTMAS.
Still nothing unless you want to blow big money on one of the high end cards...
I picked up (very affordable based on what I read) a MSI GTX750ti SC 2gb card what I call a interim card, according to what I read, it will output 2160p @ 60fps, video via HDMI 1.4a, should be good for video but, if you want to play high end games plan to break the bank a little.
Nothing yet affordable if you want HDMI 2.0 and HDCP 2.2 (not sure any cards have HDCP 2.2).. I'm kind of waiting too..
and Merry Christmas to you as well..
-Dave
MCSE 2003
Windows Media Center specialist
Avid gamer and home theater junkie..
DavidinCT is offline
Old 12-22-2014, 03:59 AM
sneals2000's Avatar
Quoted: 85 Post(s)
Liked: 62
Technically I think the interim nVidia solution is taking advantage of a new mode added with HDMI 2.0 that allows 4:2:0 chroma (HDMI 1.4a and below only supported 4:2:2 and 4:4:4) to be used. This allows 2160/60p to be carried within the bandwidth of HDMI 1.4a - so nVidia have effectively added one HDMI 2.0 mode to an HDMI 1.4a card.
sneals2000 is offline
Old 12-22-2014, 04:36 AM
Tedd's Avatar
Quoted: 252 Post(s)
Liked: 113
And that would extend to the GTX 970 and GTX 980 cards too, since they are of the same family?
Tedd is offline
Old 12-22-2014, 07:50 AM
DavidinCT's Avatar
Quoted: 119 Post(s)
Liked: 37
Yea, I know. I picked this up for really a temp card (paid $90 for it) so when we get "affordable" HDMI 2.0 with HDCP 2.2 or higher cards, then I will upgrade.
As time goes in 2015, I think month by month we will see more content available for 4K, as more and more sets are selling. I really think, till we get a 4K Blu-ray format, the PC will be about my ONLY source for 4K content, streaming or video files. Rumors of Dish, Directv and Comcast doing testing but, seeing that in homes, that is a whole different story.
-Dave
MCSE 2003
Old 04-12-2015, 06:34 AM - Thread Starter
iwanrs's Avatar
Quoted: 34 Post(s)
Any new affordable 4K/2160p Graphic Card?
For movies/video watching only, no gaming at all.
iwanrs is offline
Old 04-13-2015, 04:29 AM
rickcfer's Avatar
Quoted: 17 Post(s)
Refer to this article: http://www.anandtech.com/show/9152/f...-hdcp-and-hevc
You're welcome
rickcfer is offline
Old 04-16-2015, 07:45 AM
DavidinCT's Avatar
Quoted: 119 Post(s)
Liked: 37
Like I said, FOR NOW, I am running a GTX750ti SC 2gb card, I am running WMC @ 2160p @60hz. This is on my dedicated WMC machine.
Windows Media Center runs great @ 2160p, native 4K content (downloaded demos, or things I have gotten on other places) look as good as if I put them on a USB drive and plugged into the TV.
This is ONLY used for TV, video and movie watching, and the results are impressive at least me on my LG 65UB9500
-Dave
MCSE 2003
