Silly Question about Websockets and Androids - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 10-07-2014, 04:55 PM - Thread Starter
Somewhatlost's Avatar
Quoted: 20 Post(s)
Liked: 25
ok, so I am in no way even close to ever being a web developer... I have never played one (or anything else really...) on TV...
that said, I am trying to have a little internal webpage thingy that I can go to turn a light or two on/off...
to start with I am just using this sample/demo code and it works great... from a windows device... only from windows...
but my phone is an android, it does not run windows... (being all googly and such)
so what is different between windows and android in regards to how they handle websockets and such?
NOTE: As one wise professional something once stated, I am ignorant & childish, with a mindset comparable to 9/11 troofers and wackjob conspiracy theorists. so don't take anything I say as advice...
Somewhatlost is offline
post #2 of 8 Old 10-07-2014, 11:05 PM
Dark_Slayer's Avatar
Quoted: 722 Post(s)
Liked: 451
Should be fine if your phone is running chrome. The default ICS and before android browser wouldnt handle websockets
http://caniuse.com/#feat=websockets
Also, 8080 is getting to be a crowded default port. Flexraid and Sabnzbd both want that by default as does whatever that link you posted. Only matters if you run those services on the same local ip
Dark_Slayer is offline
post #3 of 8 Old 10-08-2014, 01:27 PM - Thread Starter
Quoted: 20 Post(s)
Liked: 25
that is what I thought... but unfortunately it is not... and I have no clue why not... going to http://www.websocket.org/echo.html from the phone, everything works as it should... but my phone does not seem to ack/respond/whatever to my demo page
this is my home automation server... while I am using port 80 for something, 8080 is open and clear...
post #4 of 8 Old 10-08-2014, 01:57 PM
NNate's Avatar
Quoted: 57 Post(s)
FYI - This seems like a better question to put on StackOverflow. I'd help if I could here, but I know nothing about WebSockets.
NNate is offline
post #5 of 8 Old 10-09-2014, 12:47 PM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 416
Sounds like you simply have a networking confusing if your phone actually works fine running the above echo test.
If your phone is connected to your local wifi network, you need to use the local IP address of your web server to test it, not the machine name (because your phone most likely can't resolve the name). If your phone is using cell network instead of wifi, you will need to create a port forwarding on your router and use your external IP (from your ISP) to connect and pray that your ISP doesn't block port 8080 (most ISPs will block common server port like port 80).
Foxbat121 is online now
post #6 of 8 Old 10-10-2014, 09:17 AM - Thread Starter
Quoted: 20 Post(s)
Liked: 25
I have tried using both internal and external networks, using IP address and name on internal, and it works great from any windows device, and not so good on the android. fwiw, I do see the website/graphics on both. it is just when I press the light bulp picture on the android nothing happens, press (on my win8 tablet) (or click on my PC win7 PC) the light both on the web page and the actual light, change states (ie On to Off or Off to On) so it seems everything, except for the actual control from an android device, works fine... just why wont the android cause a change of states?
this shouldn't be so hard...
according to the websocket test page says websockets work...
the html web page code isn't at all fancy
the little bit of java code from the demo does not seem all that special either...
I am confused...
it seems like it should work, but it just doesn't?
edit: why is AVS now reformatting my post and taking out all the line feeds and making it one big impossible to read jumble?????? has AVS banned LF's now? what next a ban on CR's?
edit2: seems AVS does not like being NOSCRIPT'ed... temp allowed AVS now I can stick CR/LC in and they seem to 'stick'
post #7 of 8 Old 10-10-2014, 10:10 AM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 416
The demo code relies on javascript, not Java, code to call the websockets, as most web pages will. If you disabled scripting on your phone's browser (as you indicated you likely do on the above post) as well, it will not work. Internet without scripting will be a very boring place.
post #8 of 8 Old 10-10-2014, 10:29 AM - Thread Starter
Quoted: 20 Post(s)
Liked: 25
as far as I know, I have not installed noscript on my phone, pretty much only go to forums on PC's...
Reply Home Theater Computers
