Help me out with a tv capture ... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 10-10-2002, 01:44 PM - Thread Starter
anton_r's Avatar
Hello,
I have hard time deciding which is the best way to go ... b/c got recommended few different ways from different ppl ...
(I have dishnetwork and capture to huffyuv and in most cases I capture old russian movies, which don't have good quality :( )
1.) Capture at like 720x480 (my max), virtualdub: smart deintarlance, resize to like 576x432 ... maybe blur , compress with divx 5
2.) Capture at 576x480 , smart deintarlance, resize to 576x432, compress
3.) Capture at 576x432 (because two above don't make much difference), smart deintarlance , compress
so, which one is the best one ?
or maybe you can recommend a better approach ?
don't want to make big resolutions, so at most computers it will play ...
but would like to get the best quality
thx a lot
anton_r is offline
Closed Thread Home Theater Computers
