Choppy Audio from Laptop DVD playback - AVS Forum | Home Theater Discussions And Reviews
post #1 of 21 Old 10-20-2002, 04:35 PM - Thread Starter
HT Pusher's Avatar
I have an HP laptop 1.13 Ghz 512 meg ram, with Windows XP Pro, that I would like to use to playback DVD's. It came with WinDVD 3.1 DXVA.
However, when I play DVD's the sound from the laptop's speakers is choppy and stuttering.
I installed PowerDVD 4.0, but this software has the same problem.
Can someone recommend a solution?
Daniel
HT Pusher is offline
post #2 of 21 Old 10-20-2002, 10:06 PM
safaa's Avatar
hi
did this happen before or after sp1 update.
if it happened after update. so you need clean install winxp pro and for get about that updates.
i have p3 hp with xppro running on it.
safaa
more speakers you buy ,more happy you are
safaa is offline
post #3 of 21 Old 10-20-2002, 11:09 PM - Thread Starter
HT Pusher's Avatar
I have not been able to upgrade to SP1 as I bought a demo from Costco that came with discs for XP Home even though the computer had Pro intalled, and when attempting to upgrade to SP1, I received an error message saying that the key was not correct and the upgrade was aborted.
I have added some Divx upgrades so that I could playback some download Simpsons episodes that I got from Morpheus.
post #4 of 21 Old 10-20-2002, 11:58 PM
safaa's Avatar
hi
is your laptop connected all time to the net. like dsl or cable. if so and you tried to update xp pro. you got buged by microsoft.
format and do clean install don`t update any more.
safaa
safaa is offline
post #5 of 21 Old 10-21-2002, 12:30 AM - Thread Starter
HT Pusher's Avatar
Yes, it is always connected through DSL. In fact, my computer notified me that I needed to perform the update through Microsoft's website.
Would you elaborate on your recommendation to format and do a clean install? Do you mean reformat my hard drive and reinstall windows?
post #6 of 21 Old 10-21-2002, 12:56 AM
safaa's Avatar
yes.
format hd. clean install. make sure you have all needed drivers for your hardware. you can down loadthem from hp site. save them to cd. in case you need it
and try to disable this puggy update on taskbar
safaa
safaa is offline
post #7 of 21 Old 10-21-2002, 01:35 AM - Thread Starter
HT Pusher's Avatar
This seems rather severe. If I do this, I will have to reload all the software on my machine and that ALOT!
Also, one of my problems is that Costco gave me backup discs for XP Home, but my machine has XP Pro loaded on it. I hate to go backwards in terms of operating systems.
post #8 of 21 Old 10-21-2002, 01:43 AM
safaa's Avatar
hi
try to install sound driver again . also for dvd software . see if that will fix it.
if not . try to get xp pro from where you get it last time.
safaa
safaa is offline
post #9 of 21 Old 10-21-2002, 01:48 AM - Thread Starter
HT Pusher's Avatar
The demo that I bought from Costco had XP Pro installed on it. I don't know if an employee installed it, or if the machine was supposed to have it and they gave me the wrong backup discs when they gave me the box for the demo.
Please excuse my ignorance, but what is the sound driver?
post #10 of 21 Old 10-21-2002, 01:53 AM
safaa's Avatar
go hp web site
http://welcome.hp.com/country/us/eng...re_drivers.htm
type your laptop model .
then search for win xp pro drivers you will see list of all drivers you need for your laptop. save them on cd you going to need them in future.
safaa
safaa is offline
post #11 of 21 Old 10-21-2002, 02:20 AM - Thread Starter
HT Pusher's Avatar
They don't have any audio drivers listed. They do have a bios update, however you need a floppy drive to perform this update, and my model does not come with a floppy drive.
post #12 of 21 Old 10-21-2002, 04:36 AM
gotapex's Avatar
Click on Start -> Control Panel -> Performance and Maintenance -> System
Then, click on the Hardware tab
Click on the Device Manager button
Click on the + next to Sound, video and game controllers
What does it say your sound chip is?
BTW, what is the exact model of HP you have?
gotapex is offline
post #13 of 21 Old 10-21-2002, 12:58 PM - Thread Starter
HT Pusher's Avatar
I couldn't find a "performance and maintenance" icon, but I was able to get to device manager through "System" icon.
Under Sound, video and game controllers there are two subcategories
1.Unimodem Half-Duplex Audio Device
2.VIA AC'97 Audio Controller (WMD)
I spoke to HP and they had me delete the other listings there were here last night, which were:
Audio Codes
Legacy Audio Drivers
Legacy Video Capture Devices
Media Control Devices
Via AC'97 Audio Controller (WDM)
Video Codes
They had me delete all seven of them and Windows restored the two mentioned above.
I can revert to the original seven with my laptop's restore feature.
I have the HP model xz185.
Thanks for your help.
post #14 of 21 Old 10-21-2002, 01:14 PM
safaa's Avatar
hi
after you delete all devices, win xp will install it for you, thats why hp site don`t have them because the drivers are in winxp .
after you reboot you shouls be ok. or else, you got bugged from MS,
is sound come out good now.
safaa
safaa is offline
post #15 of 21 Old 10-21-2002, 02:30 PM
a1rabbit's Avatar
I don't know what chipset you have but when I had this problem with my abit motherboard it was to do with my VIA 4in1 drivers. Once I got the new drivers it fixed ALL my problems. Computer ran MUCH faster, my resources did not deplete as fast and all the choppy sound went away, as did choppy video and sound if I used my video cards TV out.
a1rabbit is offline
post #16 of 21 Old 10-21-2002, 02:34 PM - Thread Starter
HT Pusher's Avatar
safaa, thanks for the info. No, I still have choppy sound. So, are you saying that Microsoft has intentionally compromised my system?
a1rabbit, I will look for VIA drivers and see if that helps.
The HP tech is now telling me to uninstall all DVD software and reinstall the Windvd that came with my laptop.
post #17 of 21 Old 10-21-2002, 02:51 PM
gotapex's Avatar
Here are the latest VIA drivers:
http://www.viaarena.com/?PageID=2
gotapex is offline
post #18 of 21 Old 10-21-2002, 03:59 PM
wjchan's Avatar
Liked: 29
That sounds fishy. Costco probably used a well-known pirated XP Pro key when they did the install. You won't be able to install SP1. Either you have to install the valid XP Home or go get a copy of XP Pro (not sure if you can use Upgrade version) and change the license key.
wjchan is offline
post #19 of 21 Old 10-21-2002, 05:42 PM
a1rabbit's Avatar
You should also try the free trial of power DVD or something, and see what happens. I and others had a lot of problems with WinDVD 2000 but I am sure you have a newer version than that.
a1rabbit is offline
post #20 of 21 Old 10-21-2002, 06:17 PM - Thread Starter
HT Pusher's Avatar
I installed PowerDVD 4.0 when I first had this problem, but I continued to have the same problem.
post #21 of 21 Old 10-21-2002, 09:24 PM - Thread Starter
HT Pusher's Avatar
Soon after buying the laptop, I found alot of personal pictures on the hard drive, pictures of Costco employees. So someone there was obviously using the demo for personal or work related purposes.
Closed Thread Home Theater Computers
