Nvidia GTX670, Onkyo PR5508, Panasonic AE8000U - HTPC blacks suck... - AVS | Home Theater Discussions And Reviews
post #1 of 6 Old 04-22-2015, 07:18 PM - Thread Starter
Archaea's Avatar
Quoted: 1240 Post(s)
Liked: 1149
Question Nvidia GTX670, Onkyo PR5508, Panasonic AE8000U - HTPC blacks suck...
I have an Nvidia GTX670 card on my HTPC. I recently stumbled upon the 0-255 dynamic range toggle that is available on the newest Nvidia drivers and thought this fixed the problem.
Not really - with further use I figured out it just gets rid of all the black detail and makes the overall picture darker - it's not better, just darker.
PS3, PS4, Xbox360 - all look great as sources - my cheap sony bluray player too. My expensive HTPC - nope. Blacks are either washed out on the 16 to 235 setting, or too black on the 0-255 setting.
No video calibration done on the Panasonic AE8000. IMO it looks good out of the box on all my other sources - just not HTPC.
What am I doing wrong - I've struggled with this black level thing on my HTPC for years, through several decent video cards (460, 560), and through a couple different projectors Panasonic AX200U, Epson 8350.
"Without subs it's just background music - with subs it's the main event!"
Archaea's Theatre Room
2011 KC Sub Shootout
2012 KC Blind Sub Shootout
My Subwoofer Recommendations by Pricepoint
Archaea is online now
post #2 of 6 Old 04-22-2015, 08:50 PM
IndianaGeorge's Avatar
If you use the 0-255 setting on the HTPC, then you would have to set the AE8000 to accept the full range (HDMI Signal Level->Expand on AE4000, should be similar on AE8000).
IndianaGeorge is online now
post #3 of 6 Old 04-22-2015, 09:23 PM - Thread Starter
Archaea's Avatar
Liked: 1149
Thanks for the suggestion - though I tried that. I feel like that's a sum zero difference. My black levels go back to inferior when I try this combination, IMO.
0-255 on NVidia card
Expanded HDMI signal level on Panasonic.
I also set the Onkyo pre/pro to 'through' meaning it isn't supposed to be doing anything to the HDMI signal.
Looks pretty similar to 16-235 in Nvidia and normal HDMI signal level on Panasonic.
By the way, unless I choose full screen videos from the bottom drop down on the driver control panel - 0-255 with expanded looks really washed out on everything.
post #4 of 6 Old 04-23-2015, 12:20 AM
I have an AMD setup, so I'm not that familiar with Nvidia, so hopefully someone who is will chime in. I'm not sure what the "digital vibrance" is doing. Also, you might want to show screen shots of the "adjust video color settings" and "adjust video image settings". I would also suggest trying to connect directly to the projector to rule out that the Onkyo is doing anything funny.
post #5 of 6 Old 04-23-2015, 04:31 AM - Thread Starter
Archaea's Avatar
Liked: 1149
All the color settings are default, including the digital vibrance setting. If you turn digital vibrance all the way down the colors all dissapear completely and you are left with black and white. I will try pc directly to projector. Good call there.
post #6 of 6 Old 04-23-2015, 05:14 AM
mrfattbill's Avatar
Quoted: 40 Post(s)
Liked: 68
My GTX760 feeding my Panasonic plasma is set to YCbCr444 and full screen video.
Bill
mrfattbill is offline
Reply Home Theater Computers
