NOOB HTPC build help please - AVS | Home Theater Discussions And Reviews
post #1 of 2 Old Today, 09:58 AM - Thread Starter
Liked: 0
so here are 2 different builds I would like your opinion on please.
My goal is to decrease my cable bill as much as possible, hopefully just pay for internet. I will have WIN7 with WMC and a HDHOMERUN (not sure if I should go with the cable card model or the QAM model) running on the HTPC. Also I will be adding XBMC for the things it has to offer (movies etc.) I have a intel nuc celeron now which does fine but gets kind of pixely with the 1080p stuff (I will end up just putting it in the bedroom).
Also what are your though for either of these having a video card? or sound card?
Build 1: Assasin basic build minus the optical drive (dont need it)
http://secure.newegg.com/WishList/Pu...umber=18178889
Build 2: http://techbuyersguru.com/HTPCbuild.php
thank you for your input, I appreciate it
kdubb2772 is online now
post #2 of 2 Old Today, 10:27 AM
TornadoTJ's Avatar
Quoted: 311 Post(s)
Liked: 118
1. You can rebuild your NUC with OpenELEC and it will work great. Installing PleXBMC will get you connected to your new HTPC.
2. I wasn't sure which box on techbuyers you wanted me to look at, so I ignored that page. The Assassin's recommendation will work just fine.
3. You don't need a video or sound card, it's built-in.
TornadoTJ is online now
Reply Home Theater Computers
