No sound on Mk4 or MP4 files - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 02-07-2016, 06:45 AM - Thread Starter
Liked: 0
Hi,
Someone has given me some mkv and mp4 files but l cannot get any sound to play on the movies.
I have ffdshow codec and K-lite Code player but still not luck.
Any help would really be appreciated as to how get sound working , video is fine.
Justin
nitsuj1972 is offline
post #2 of 4 Old 02-07-2016, 06:53 AM
tman247's Avatar
Quoted: 57 Post(s)
Liked: 51
Download and install mediainfo (make sure you select the shell extension), then right-click the file and have a look at the 'MediaInfo' properties. It will tell you exactly what's in the container.
tman247 is offline
post #3 of 4 Old 02-07-2016, 10:05 AM - Thread Starter
Liked: 0
Originally Posted by tman247 View Post
Download and install media info (make sure you select the shell extension), then right-click the file and have a look at the 'MediaInfo' properties. It will tell you exactly what's in the container.
Hi,
Audio stream: AC-3/AAC
video stream: AVC
Is that any help?
post #4 of 4 Old 02-08-2016, 06:04 AM
tman247's Avatar
Quoted: 57 Post(s)
Liked: 51
Originally Posted by nitsuj1972 View Post
Hi,
video stream: AVC
Is that any help?
It's pretty much a bog standard audio stream. Nothing special at all. Do you get audio when playing it back in MPC-HC?
tman247 is offline
Reply Home Theater Computers
