Attached is the info of two rips made with makeMKV1.9.1.0beta(latest version)
Both rips include multichannel info.
Both rips play as stereo PCM as identified by the preamp.
I will also make a 'backup' with makeMKV and test the files it makes in the BDMV folder.
If you are now saying that TMT5 treats isos and video files differently, which software player do you use to get DTS-MA output?
I know I can get get bitstream output from TMT5 because my preamp identifies the audio correctly when it comes from an iso image.
@Keenan
using the settings you recommended for makeMKV gave the following output
Loaded content hash table, will verify integrity of M2TS files.
Title
#00020.mpls has length of 96 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title
#00050.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title
#00051.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title
#00052.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title
#00070.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title
#00071.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title
#00072.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title
#00090.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title
#00091.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00800.mpls was added as title #0
File 00801.mpls was added as title
#1
File 00802.mpls was added as title
#2
Title 00803.mpls is equal to title 00800.mpls and was skipped
Title
#00002.m2ts has length of 29 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title
#00001.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title
#00003.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title
#00004.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title
#00005.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title
#00029.m2ts has length of 48 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title
#00030.m2ts has length of 48 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title
#00007.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title
#00135.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title
#00136.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title
#00137.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title
#00143.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title
#00144.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title
#00145.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title
#00147.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title
#00148.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title
#00149.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title
#00150.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00151.m2ts was added as title
#3
File 00153.m2ts was added as title
#4
File 00154.m2ts was added as title
#5
File 00155.m2ts was added as title
#6
Profile parsing error: Invalid token '-sel:-sel:all'
Operation successfully completed
Despite the error, it still did the rip.
It still generated the same mkv file that appears as 'stereo PCM' on the preamp display though the mediainfo on the file shows a 7.1 track present.
