HTPC decoding Dolby Atmos? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 28 Old 08-25-2016, 01:36 PM - Thread Starter
jorsan's Avatar
Quoted: 38 Post(s)
I would like to avoid the use of a processor to decode Dolby Atmos ... is there any way to decode the codec inside the computer?. Thank
jorsan is offline
post #2 of 28 Old 08-25-2016, 01:40 PM
styjp's Avatar
Quoted: 47 Post(s)
Liked: 44
i would also like to know but as far as I know there is none. I think our only hope would be cyberlink but no word on atmos yet I hope I am wrong
Styj
styjp is offline
post #3 of 28 Old 11-02-2016, 03:24 PM
deandob's Avatar
Quoted: 40 Post(s)
Liked: 24
Any news on options for ATMOS support for HTPC's? Especially the software Blu-ray players?
deandob is offline
post #4 of 28 Old 11-03-2016, 08:07 AM
Sammy2's Avatar
Quoted: 515 Post(s)
Liked: 250
Doesn't LAV do this? There's a discussion on it over on the Emby Forums.
Sammy2 is offline
post #5 of 28 Old 11-03-2016, 09:15 AM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 402
Isn't Windows currently limited to LPCM 7.1 max? If so, what's the point to decode at PC side?
Foxbat121 is online now
post #6 of 28 Old 11-03-2016, 12:55 PM
Mrkazador's Avatar
Quoted: 260 Post(s)
Liked: 388
You can bitstream atmos but not playback on pc, you are limited to 7.1.
Mrkazador is online now
post #7 of 28 Old 01-24-2017, 07:14 AM
DavidML3's Avatar
Quoted: 143 Post(s)
Liked: 61
How do you do this on Windows 10?
DavidML3 is offline
post #8 of 28 Old 01-25-2017, 02:06 AM
Mrkazador's Avatar
Quoted: 260 Post(s)
Liked: 388
LAV audio filter can passthrough Dolby Atmos, you need to enable bitstreaming.
post #9 of 28 Old 02-03-2017, 11:09 AM
erik.vanhamme's Avatar
Quoted: 37 Post(s)
Liked: 1
It's not true that you are limited to 7.1 on Windows. The windows audio stack is limited to 7.1, but there is nothing preventing you from using ASIO to output to a DAC with more then 8 outputs. I do this very thing right now to a Focusrite 18i20. I output 10 channels (7.3).
The only problem is that the decoding software must be ASIO capable, and smart enough to decode the atmos bitstream. I suspect JRiver MC is the closest at the moment. They don't have atmos decoding, but they are certainly capable of outputing to ASIO DAC.
erik.vanhamme is offline
post #10 of 28 Old 02-06-2017, 01:44 AM
mightyhuhn's Avatar
Quoted: 737 Post(s)
Liked: 250
the decoder has nothing to do with ASIO this is only about the audio renderer.
and now about atmos decoding and why it is pointless.
let's assume we can decode an atmos encoded audio stream.
so we can decode it and do what with the 16+ channels?
all these channels need to be mixed to your atmos setup and how to get these information. well we can't get these information.
your atmos AVR can do this because it has the position of your speakers too.
unlike 5.1 or 7.1 there is no fixed speaker position for atmos.
mightyhuhn is offline
post #11 of 28 Old 02-06-2017, 05:39 AM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 402
While it is true, there is nothing that can prevent you configure the speaker settings, e.g. layout and distances in PC decoder and decode/mix the ATMOS into 5.1.2, 7.1.2 etc. The question is will any software maker do this (and paying licensing fee) knowing that it can't output via regular HDMI but rely on certain soundcard capability? Probably not.
post #12 of 28 Old 02-09-2017, 11:06 PM
curtisb's Avatar
Quoted: 29 Post(s)
Liked: 39
Will? Nobody here can answer that.   Personally, I don't see much unless you are dead set on using your pc as pre vs having a separate pre with your pro or a receiver.   And if you care about Atmos, you should also care about DTS X support so your PC would need to support both which likely wouldn't happen at the same time.
curtisb is offline
post #13 of 28 Old 02-09-2017, 11:56 PM
markus767's Avatar
Quoted: 3766 Post(s)
Liked: 1347
HDMI 2.0 and higher can output 32 audio channels. http://www.hdmi.org/manufacturer/hdmi_2_0/index.aspx
There's just no device (yet) on the receiving end. Then again why not just DA at the soundcard output and directly feed an amp.
Markus
"In science, contrary evidence causes one to question a theory. In religion, contrary evidence causes one to question the evidence." - Floyd Toole
markus767 is offline
post #14 of 28 Old 02-10-2017, 03:47 AM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 402
As mentioned above, windows currently only support 7.1 max on HDMI. So, you will have to write decoder for a specific sound card targeting 0.1% of the market.
Sent from my Venue 8 7840 using Tapatalk
post #15 of 28 Old 02-10-2017, 03:53 AM
markus767's Avatar
Liked: 1347
That 0.1% is probably 99% of your target market
Markus
post #16 of 28 Old 02-10-2017, 07:26 AM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 402
I'm not the one creating such software. How about you invest in it and see how it works out
post #17 of 28 Old 02-10-2017, 07:32 AM
markus767's Avatar
Liked: 1347
I don't believe in HTPC. Cluttered interface and lack of crucial content/apps. It seems to be more likely that we will see streamers with bitstream passthrough and no-frills boxes that do the decoding and speaker setup/room EQ.
Anyway, guess you've missed my point. You've claimed "can't output via regular HDMI" which is not correct.
Markus
post #18 of 28 Old 02-10-2017, 07:36 AM
mightyhuhn's Avatar
Quoted: 737 Post(s)
Liked: 250
so nvidia, intel and amd support more than 7.1 pcm output?
post #19 of 28 Old 02-10-2017, 07:58 AM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 402
This is, after all, HTPC forum and OP is asking a question regarding HTPC. Please keep that in mind before you nitpicking.
post #20 of 28 Old 02-10-2017, 08:00 AM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 402
It is not like more audio channels require additional pins on HDMI port. But GPUs are limited to whatever audio data the OS driver can send to it.
post #21 of 28 Old 02-10-2017, 08:18 AM
stevedawg85's Avatar
Quoted: 28 Post(s)
noob question - Why do I/you want a processor to decode - what is a "processor", do you mean the A/V receiver?
I'm about to configure an ATMOS setup myself w/ a WIN 10 machine and Radeon R9 290. Is ther something I should be aware of? I watch all my content in Kodi w/ passthrough checked off. So does that mean there is more stress on my receiver or HTPC?
stevedawg85 is offline
post #22 of 28 Old 02-10-2017, 08:29 AM
cswiger's Avatar
Quoted: 229 Post(s)
Liked: 96
Either the AVR or a HTPC can decode Dolby Digital and DTS streams and perform upmixing through 7.1 channels.
However, at present, only an AVR with Atmos capabilities (or DTS:Neural X) can decode or upmix to the height channels.
Yes. You'll need to enable passthrough if you want the Atmos signal to, well, pass through.
Also, you'll need to disable 'sync playback to display' in the video settings or that will prevent bitstreaming.
Primary (2.1): Thiel CS 1.2 / Velodyne F1000 sub / Adcom GFA-555 Mk2 / Rotel 970BX / Sony CDP-CA9 ES
Secondary (5.1): Paradigm Mini-Monitor v.3 / CC270 v.3 center / ADP-170 v.2 surrounds /
SVS SB1000 sub / Marantz SR-6010 / AppleTV + Win7 PC / BenQ BL3200PT
cswiger is online now
post #23 of 28 Old Yesterday, 07:18 AM
Quoted: 21 Post(s)
Liked: 7
Then you have no idea how to properly build one. Leave it to people who know what they're doing then, because a HTPC is superior to any stand-alone box once properly configured and implemented. There are lots of moving parts but once you have the knowledge and skill to execute it correctly, there is no comparison. All decoding should be done through a separate pre-amp or digital processor. Let the HTPC pass through all formats, including Atmos, which they can do. They are not a replacement for a dedicated preamp nor should they be. They are a front end, period.
Freddy Ford is offline
post #24 of 28 Old Yesterday, 07:20 AM
markus767's Avatar
Liked: 1347
It's not that I don't know what I'm doing it's more like HTPCs don't do what I want and they don't do it the way I want. They probably never will. Been there done that.
Markus
post #25 of 28 Old Yesterday, 07:51 AM
smoothtlk's Avatar
Quoted: 22 Post(s)
Isn't that just a function of the software running on the HTPC?
"It's not that I don't know what I'm doing it's more like HTPCs don't do what I want and they don't do it the way I want. They probably never will. Been there done that."
How do you want it to be...and what have your tried?
smoothtlk is online now
post #26 of 28 Old Yesterday, 08:06 AM
markus767's Avatar
Liked: 1347
Isn't that just virtually always the case?
More or less all of it? I'm working in the AV/IT industry for over a decade now. Not interested in discussing my opinion on HTPCs here. It's just not worth it. Been there done that too.
Markus
post #27 of 28 Old Today, 10:23 AM
ToiletDucky's Avatar
What's the point of ATMOS? Can anyone actually tell the difference? There's so many formats out there they just seem like sales pitches. My setup sounds amazing and I can't tell any difference between the high end codecs.
ToiletDucky is online now
post #28 of 28 Old Today, 10:35 AM
markus767's Avatar
Liked: 1347
The official Dolby Atmos thread (home theater version)
Markus
Reply Home Theater Computers
