Cheap sound card with optical out on back - AVS Forum | Home Theater Discussions And Reviews
post #1 of 18 Old 05-06-2003, 06:29 AM - Thread Starter
PretzelB's Avatar
Are there any inexpensive sound cards with optical outputs on the back? I want to demo a HTPC to see if I like it but I'm not ready to commit to the project yet. I bought a cheap 16x Sony DVD drive but I don't think my SB Live card can be hooked up to my Yamaha receiver without an optical connection. My SB has outputs for front and rear spearkers but nothing for sub and center (unless that's what the digital out is for). Also, I think my receiver is only able to accept either a single optical or dual rca input. I assume that if I run a mini to rca plug from the front SB connection to my DVD rca input connections on my receiver that I won't get 5.1 so I'm looking at the new sound card.
PretzelB is offline
post #2 of 18 Old 05-06-2003, 06:36 AM
KWhite's Avatar
AOpen AW850D or Chaintech AV515M, both can be found for under $25.
KWhite is offline
post #3 of 18 Old 05-06-2003, 06:37 AM
irwincur's Avatar
Get the Hercules cards. You can find an OEM box for about $40 and they actually put out some really good sound.
irwincur is offline
post #4 of 18 Old 05-06-2003, 09:59 AM
lovebohn's Avatar
Has anyone used a Maya..........I saw them at CompUSA this past weekend. I have a Sound Blaster Live Value with the daughter card for a digital optical connection and have bad luck getting any sound to my Denon 3802.
Dave
Revised:
I uninstalled all the programs with the sound card and just installed the drivers and had 100% perfect luck with all MP3's, DVD's, DD and DTS output to my receiver.
lovebohn is offline
post #5 of 18 Old 05-06-2003, 10:14 AM - Thread Starter
PretzelB's Avatar
I hadn't heard of these before. They certainly meet the criteria. I used to be scared of no name audio cards from the Win 95 and Win 98 days but I suppose drivers and IRQ handling is much better now so it's not so dangerous.
I will have to consider the Hercules cards too. I had no idea you could get them so cheap for so many features.
Just out of curiousity, if you pipe the sound from your pc to your receiver does it really matter how good the sound card is? Doesn't your receiver take over the processing? I should probably make this another post.
PretzelB is offline
post #6 of 18 Old 05-06-2003, 10:44 AM
bugman72's Avatar
Check out the Nightingale Pro 6. You can get it for less than $40. I've been using one for over a year and a half and love it. It's got SPDIF-In and Out as well as Digital Coax out.
"Can I refill your eggnog, Eddie? Drive you out to the middle of nowhere and leave you for dead?"
Greg Jones
My Former Theater...The Escape
My DVD Collection
bugman72 is offline
post #7 of 18 Old 05-06-2003, 12:05 PM
kasarah's Avatar
Does the sound on the SPID get decoded into Dolby Digital DTS?
I have a SPID on the back of my card, and I'm not seeing the lovely blue light come on my Sony receiver indicating digital optical 5.1. :(
(I have a now defunct company Fortissimo with a SPID on the back).
Bill
kasarah is offline
post #8 of 18 Old 05-06-2003, 12:08 PM
mikef's Avatar
Do the newer Hercules cards still have the limitation where you have to reboot to switch between Windows sound and DVD sound (ie. through PowerDVD)? This is a major issue for me with my Fortissimo II.
mikef is offline
post #9 of 18 Old 05-06-2003, 04:46 PM
IUnknown's Avatar
Ahem, you said cheap. $14 for a Nightengale clone (AVM515) at Directron. Its the same hardware.
IUnknown is offline
post #10 of 18 Old 05-06-2003, 06:19 PM
irwincur's Avatar
Wow, I just read a few reviews of the Nightengale - sounds like a great card for this purpose.
And yes, you do still need to reboot with the Hercules. Now that I think of it, that is complete BS.
irwincur is offline
post #11 of 18 Old 05-06-2003, 07:12 PM
mikef's Avatar
I am going to have a look at that card as well.
Their technical support promised the problem would be fixed almost 2 years ago. So much for Hercules... another sound card manufacturer to join Creative Labs on my most hated list.
mikef is offline
post #12 of 18 Old 05-07-2003, 05:29 AM - Thread Starter
PretzelB's Avatar
Someone must have thought it was a great deal - I see this as being sold out at Directron.
PretzelB is offline
post #13 of 18 Old 05-07-2003, 05:39 AM
irwincur's Avatar
Too bad it is sold out. A quick sear for 'audio excel" cards did not bring up any other places that have it. I did find one on eBay but the seller does not have any of the details listed. Not even the model number.
irwincur is offline
post #14 of 18 Old 05-07-2003, 06:30 AM
airduct's Avatar
I am also looking for a sound card and here is what i found:
1) directron is out of stock, but the price for the av515m is $15 + 6s/h = $21
2) Newegg has the chaintech av515m for $19+4s/h=$23
3) Newegg has the Aopen aw850D for $23 +0s/h+ $23
go for Newegg's aopen aw850D since it has optical in/out also and also very reputable dealer w/ fast delivery and great service. good luck
airduct is offline
post #15 of 18 Old 05-07-2003, 06:48 AM
irwincur's Avatar
I just found the Chaintech av515m (same as the Nightengale and the avm515) on www.googlegear.com. It was $23 with free shipping - not bad for a good looking card. However, everywhere I see this card the optical out part is listed as the OP101 and none of the vendors say whether or not it really comes in the box.
Just wondering if the OP stands for optical or optional - you just never know.
irwincur is offline
post #16 of 18 Old 05-20-2003, 06:32 AM - Thread Starter
PretzelB's Avatar
I bought the AOpen AW850D from NewEgg and installed it last night. The optical connection setup was really a royal pain but I finally figured it out after viewing the online forum for Aopen. Initial results are really good. I need to test it more but I can't believe how good it sounds for so cheap a card. DVD movies came thru the receiver with no problems.
My next task it to try and figure out how to get the ATI TV tuner to work with the receiver while keeping the DVD stuff working. It's probably a connection that I've screwed up.
PretzelB is offline
post #17 of 18 Old 05-20-2003, 06:42 AM
HofstraJet's Avatar
Quoted: 17 Post(s)
Looking at the pictures on newegg.com, it appears as if the daughterboard is included. Perhaps an email to newegg to ask them is in order?
HofstraJet is offline
post #18 of 18 Old 05-20-2003, 12:27 PM
kairos's Avatar
does anyone have a link to buy the Nightingale Pro 6 in the states. I can't find any place that has them in stock or even sells them. I'd perfer a store as opposed to e-bay. thanks.
kairos is offline
Closed Thread Home Theater Computers
