another help me build a system thread - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 09-03-2016, 10:10 PM - Thread Starter
sgtarky's Avatar
I have a pretty good system setup but it is pretty old and bulky. I build it in 08 and the only thing I have had to do to it since was add a sd drive for the os and windows 8.1. BUT IT IS HUGE! We are big fans of WMC and we use a Hauppauge tuner, our cable provider has local channels on it too. I also have a apple tv3 roku, xbox one, xbox 360, none of these will ever replace the htpc. I was expecting something from appletv4 but that appears to be a let down , then there is xbox one s and its probably too new to function correctly , altho it does have a haupauge tuner but its for over the air. I guess I will go with a nuc style. I would also like some good tips on a soundsystem ours is from 2002 lol
sgtarky is offline
post #2 of 10 Old 09-03-2016, 10:13 PM
Quoted: 473 Post(s)
Liked: 185
I recommend checking this place out for a HTPC build
http://www.overclock.net/f/237/htpc
as far as tips for a sound system just curious at what exactly you are looking for. Budget. Room size. Ect
Theriddler07sms is offline
post #3 of 10 Old 09-04-2016, 11:03 AM
Onkyoman's Avatar
Quoted: 156 Post(s)
Liked: 75
Onkyoman is offline
post #4 of 10 Old 09-05-2016, 06:36 AM
Liked: 1
If you can narrow down your build a little bit I have found the /r/buildapc subreddit on Reddit to be a big help.
bunsenburner156 is offline
post #5 of 10 Old 09-06-2016, 01:36 PM
TornadoTJ's Avatar
Quoted: 1717 Post(s)
Liked: 539
Where are the movies going to be stored? If locally, don't go the NUC route. You end up with a real nest of wires if you do. That's how I did my father's and I regret it. Two boxes (NUC and external drive), two power bricks, cabling between the drive and the NUC, cable for IR receiver... it looks like crap. A MicroATX system would have made much more sense. I built a MicroATX to be my bedroom HTPC a long time ago and now it's my wife's desktop. Plenty of room for an SSD boot drive and a large hard drive inside the case, so it's nice and neat.
I still have what used to be my HTPC, I'm typing on it now. It's in a huge Antec case. I never cared that it was big, it was in a cabinet so it did not show. Why start over just because it is big?
TornadoTJ is offline
post #6 of 10 Old 09-07-2016, 03:25 AM - Thread Starter
sgtarky's Avatar
yeah, that's what I have an ANTEC Fusion case. I planned on using the NUC's with 2 , 4 TB notebook hd's all of this can be hidden behind tv. Oh and I use a Bluetooth Logitech mini dinovo , it is awesome I bought it 6 years ago but it has taken some abuse , busted up a little bit I will probably get another one. I think now I'll just look into the NUC route. tired of waiting on some company that makes an all in one solution.
sgtarky is offline
post #7 of 10 Old 09-07-2016, 06:29 AM
TornadoTJ's Avatar
Liked: 539
A NUC with two external drives is going to be messy. And you didn't mention if you cared about Netflix, Amazon, etc. I replaced all my HTPCs with NVidia Shields.
post #8 of 10 Old 09-07-2016, 09:04 PM - Thread Starter
sgtarky's Avatar
yes I like to use Netflix. I don't thing shield does any cable tuning.
sgtarky is offline
post #9 of 10 Old 09-08-2016, 06:40 AM
TornadoTJ's Avatar
Liked: 539
Sure it does. That's one of the major things I use them for.
http://www.silicondust.com/product/hdhomerun-prime/
How are you going to play Netflix on NUC? Mouse and keyboard?
post #10 of 10 Old 01-14-2017, 03:52 AM - Thread Starter
sgtarky's Avatar
ok, I got a hp prodesk 600 g1 mini, its pretty awesome. I have win 10 installed, WMC and KODI . I just ordered the SD hDhomerun prime. I couldve sworn a few months ago it was close to 200 dollars, its now under 110!!!!
sgtarky is offline
Reply Home Theater Computers
