Custom Driver Question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 06-01-2003, 09:06 PM - Thread Starter
Majedesi's Avatar
I did a clean install of the new cat. drivers for my ATI AIW 9700, everything is working fine except when I try interlace resolutions. I know 1920x1080i will work because it has worked in the past. Only this time when I try to add the resolution in power strip it tells me my computer will not accept that resolution. In the power strip display properties it says my max resolution is 1912x1072 at 60 Hz.
Now my question:
Do I have to create a custom driver? and if so, I'm using a 27" Samsung HDTV for my monitor, How do I create this custom driver?
I tried to create a custom driver awhile back but I didn't quite undestand what I was doing.
Majedesi is offline
Closed Thread Home Theater Computers
