Antec Black Fusion, motherboard ideas - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 01-22-2017, 10:47 PM - Thread Starter
sgtarky's Avatar
I build a HTPC back in 08, using an Antec Black Fusion , quad amd phenom . Its been working great but I know power/heat management has gotten alot better, it has been getting hot lately(yes I cleaned everything), I had to set it on top of my entertainment center instead of inside it. I am thinking of getting a smaller and possibly fanless motherboard and using extra space for laptop harddrives. suggestions on motherboards, and have any of you done the same thing with this case.
sgtarky is offline
post #2 of 8 Old 01-23-2017, 03:12 PM
LexInVA's Avatar
Quoted: 661 Post(s)
Liked: 269
Ya gotta give us the case model. "Antec Black Fusion" covers multiple cases.
LexInVA is online now
post #3 of 8 Old 01-23-2017, 10:23 PM - Thread Starter
sgtarky's Avatar
sorry, 430
sgtarky is offline
post #4 of 8 Old 01-24-2017, 04:41 AM
LexInVA's Avatar
Quoted: 661 Post(s)
Liked: 269
My thoughts are the following....
1. Don't bother with an mATX board. The case doesn't have enough bays to take advantage of anything beyond a low-end mini-ITX board with four SATA ports. A mini-ITX board that uses M.2 and a low-end quad-core 2017 CPU or APU would be perfect.
2. Don't bother with laptop drives. Just get two 4TB desktop drives and call it a day. If you need more storage, you can easily add an eSATA storage tower.
3. If you have one of the 430 models with a 5.25 bay, you may want to upgrade to a new Blu-Ray drive once UHD-BD on PC is finalized.
4. Upgrade the PSU. Just do it. You can get a silent modular one if you want to maximize airflow/cooling and minimize noise.
post #5 of 8 Old 01-24-2017, 04:50 AM
bryansj's Avatar
Quoted: 1376 Post(s)
Liked: 638
And get a proper USB IR receiver and disconnect the Soundgraph/iMon crap that is built in.
bryansj is online now
post #6 of 8 Old 01-24-2017, 08:23 PM - Thread Starter
sgtarky's Avatar
i never use that panel, and I use bt keyboard with it.
sgtarky is offline
post #7 of 8 Old 01-25-2017, 02:49 PM
mobilelawyer's Avatar
Odd that you would ask... I have that case and recently looked into replacing the motherboard, but keeping the Phenom II X6 1075T processor. I figured I could upgrade to USB 3 and DDR3 ram for about $100.00. Yes, the 6 core phenom II does put out some heat, but I was thinking about going with the onboard Radeon 3000 video in this micro ATX Asus board:
https://www.newegg.com/Product/Produ...36&ignorebbr=1
With regard to the built-in IR, one thing that the ancient iMon software does is allow you to substitute an MCE compliant remote, preserving full Mediacenter functions AND turning the computer on and off with the remote, which is a nice feature, and without any outboard blaster.
I would be curious to know what you decide to do.
mobilelawyer
Samsung PN 59D7000 for broadcast and OTT only
Intel NUC D54250WYK, HD Homerun Connect,
TiVo Roamio, Nvidia Shield, Sony Playstation Vue
Netflix, Hulu, Amazon Prime
mobilelawyer is online now
post #8 of 8 Old 01-27-2017, 06:00 AM
StardogChampion's Avatar
Quoted: 93 Post(s)
Liked: 160
As far as Radeon HD3000 goes, it does not support bitstreaming of HD audio (Dolby True-HD/DTS Master Audio) if that is something you care about. Any semi-recent AMD or Nvidia GPU will fix that though -- HD5450 or better, GT610 (I think?) or better. I have fanless GT710s and GT730s in my HTPCs and they're great.
StardogChampion is offline
Reply Home Theater Computers
