HDMI Splitter for 4K hdr and HD Audio - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 02-21-2017, 08:55 AM - Thread Starter
BuddyRich's Avatar
My HTPC has a gtx 1060 which runs directly to my TV (LG OLED B6) as my AVR doesnt support 4k. i can passthrough audio from the TV but only PCM 2.0 and DTS and DD.
Ive experimented running hdmi to tv and dvi to hdmi to AVR and that worked but i get a 2nd display and headaches with it.
Is there any hdmi splitter that sends video to tv and audio to another (or full signal to both) that supports hdr?
BuddyRich is offline
post #2 of 14 Old 02-21-2017, 09:25 AM
stanger89's Avatar
Quoted: 3563 Post(s)
Liked: 1976
The HD Fury Integral can split, but it still sends audio and 4K video. You might need the Integral and the Linker if your AVR isn't happy with getting a 4K input.
stanger89 is online now
post #3 of 14 Old 02-21-2017, 03:18 PM
Quoted: 154 Post(s)
Liked: 90
Your best bet is to use the 2nd hdmi from motherboard if available. The only "pain" is when upgrading drivers to your video card. You need to unplug hdmi connected from motherboard to avr before uninstalling driver to undetect 2nd monitor. After driver upgrade, insert hdmi cable back into motherboard/avr and your good to go. Right click on speakers/headphones - left click playback devices - look for your avr and right click - set up options and mark as default sound provider. Only way you will receive HD dts - dolby (lossless 5.1 - 7.1).
Friendlys is offline
post #4 of 14 Old 02-22-2017, 03:56 AM
Nima's Avatar
Quoted: 113 Post(s)
Liked: 115
Sorry to hijack this thread. I was under the impression a 1060 could even use 3 devices. I was planning to use DVI for my monitor. HDMI to my Epson LS10000 projector and DP or 2nd HDMI to AVR.
This card should do the trick right? https://www.newegg.com/Product/Produ...82E16814126122
Nima is offline
post #5 of 14 Old 02-22-2017, 02:30 PM - Thread Starter
BuddyRich's Avatar
It "works" with multi outputs from the card, including hd audio, only you have a 2nd display in windows and some programs have a habit of opening on it and not my main one which is set as main. Also i seem to sometimes get a no signal problem because it briefly checks monitor 1 first and thinks 2nd display is dead. not sure if its a windows 10 bug or a problem because display 1 is 4k and display 2 is 1080p...
post #6 of 14 Old 08-29-2017, 10:34 AM
vick82sydney's Avatar
hi.. i cant get audio to work.. i have the hdmi straight to projector and am using the displayport with a displayport to hdmi adapter to my sound bar..
it shows the sound bar as the audio device in windows ... but no sound will play from the sound bar
any ideas ?
vick82sydney is offline
post #7 of 14 Old 08-29-2017, 12:41 PM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 416
For any HDMI device to play sound, it needs to be setup a secondary screen in Windows. No screen setup, no sound. Hence what OP said the headaches of multi-screen setup.
Foxbat121 is online now
post #8 of 14 Old 08-30-2017, 12:25 AM
so it doesn't matter that the soundbar is showing as the sound playback device ? so as it is a sound bar i cant setup as second screen obviously ?
post #9 of 14 Old 08-30-2017, 12:33 AM
guess this my only option:
http://www.auselectronicsdirect.com....0aAoMgEALw_wcB
since i'm using a soundbar i guess its ok that i can only use optical audio with this device..
i didn't have this problem in my previous setup as i had a proper theater room and an AVR that supports HDR... this is why i am trying to use it this way as the sound bar isn't HDR pass through compatible and even if it was i would have to use long hdmi cables which will only cause more headaches when it comes to HDR... My projector is HDR compatible.
post #10 of 14 Old 08-30-2017, 12:53 PM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 416
You can use your motherboard digital audio out to achieve the same thing without paying $90 for a device which does the same thing.
Sent from my ZTE A2017U using Tapatalk
post #11 of 14 Old 09-07-2017, 10:31 AM
Warren_G's Avatar
I have a similar problem in that my AVR seems to not approve of my old projector for HDCP so I get no picture via HDMI through it. I went with a simple splitter like this:
https://www.monoprice.com/product?p_id=10249
HDMI from the HTPC to the input and outputs to the AVR and projector. It works like a charm, no second display to figure out, no complex configuring of audio or video settings, and supports all audio and video formats/resolutions without a problem.
Warren_G is offline
post #12 of 14 Old 09-12-2017, 12:18 AM
motherboard didn't have optical... already tried with a pci soundcard with optical.. but the sound wouldnt work no matter what i tried.. and i did select it as playback device in windows... it shows the equalizer but sound wouldn't come out of the sound bar ... maybe it would have worked if my motherboard has optical.. maybe clash of to many devices... motherboard sound, nvidia card and a sound card
post #13 of 14 Old 09-12-2017, 12:20 AM
so this device can split video and audio between hdmi output 1 and 2 ? i would prefer this over optical
but i cant use it as its not enough bandwidth for HDR .. but maybe there is simliar one that supports 18Gbps
post #14 of 14 Old 09-18-2017, 06:24 PM
stm69's Avatar
Quoted: 17 Post(s)
Liked: 26
Any recent solutions to this setup? I have an older AVR and a JVC RS400. Would like to get 4K HDR to projector but DTS-MA on the AVR. Is there a 2 HDMI output reasonably priced HTPC card available? Old motherboard, doesn't have HDMI or digital out.
stm69 is offline
Reply Home Theater Computers
