Hercules Game THEATER XP Win2K question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 05-04-2001, 09:28 AM - Thread Starter
TimHuey's Avatar
Quoted: 51 Post(s)
Is anyone getting AC3 out from either the toslink or spdif from this card under Win 200, SP1 and WindDVD? There are reports on the internet that it works fine but I have my doubts.
Tim
HTPC. Onkyo 636, Polk audio speakers and Klipsch sub. KHO-7 Outdoor speakers. Homeseer homecontrol over Z-wave.
TimHuey is offline
post #2 of 5 Old 05-04-2001, 03:22 PM - Thread Starter
TimHuey's Avatar
Quoted: 51 Post(s)
Does everyone use the SBLive?
tim
TimHuey is offline
post #3 of 5 Old 05-05-2001, 08:46 AM - Thread Starter
TimHuey's Avatar
Quoted: 51 Post(s)
I don't think I should take that as a yes. I can't believe in all the members here no one is using this under win2k and windvd.
Tim
TimHuey is offline
post #4 of 5 Old 05-05-2001, 09:59 AM
Dan Bither's Avatar
I really don't uses the HTPC for DVD playback - (I use it for HDTV playback from my HiPix and as an audio jukebox.) but it does work with PowerDVD.
I image that if PowerDVD works that WinDVD should should work too.
Dan Bither is offline
post #5 of 5 Old 05-05-2001, 11:29 AM
xcel's Avatar
Hi Tim:
___I thought I have seen you in the Creative newsgroups asking this as well … If I remember correctly, Namlemez had an XP Game Theater under Windows 2000 working correctly. He usually visits in spurts so possibly a quick E-mail could get you up and running. Given the AC97 Creative cards can use PowerDVD 3.0.xxxx or the upgraded VRX under Windows 2000, this may be something for you to use as well. The M-Audio cards pass-thru DD or DTS using either PowerDVD 2.55.0620 or WinDVD 2000 under Windows 2000. I would try PowerDVD 3.0.xxxx or the upgraded VRX as Dan has mentioned instead … Do you see a pattern developing?
___If you have not checked into the Hercules forum yet, I would highly recommend that you do this as well. There are some smart mods over there in regards to the various Hercules HW but unfortunately; their forum interface is trash. Hopefully they will be able to help you directly.
___Good Luck
___Wayne R. Gerdes
___Hunt Club Farms Landscaping Ltd.
___ xcel@midwest.idsonline.com
New E-Mail address for the time being ... waynegerdes@earthlink.net
xcel is offline
Closed Thread Home Theater Computers
