AccessDTV:No longer get audio from NTSC channels - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 05-04-2001, 08:19 PM - Thread Starter
jaam's Avatar
This is nice. I no longer get any audio analog channels. It just stopped woking. It still works on DTV both pc and ac3.
jaam is offline
post #2 of 9 Old 05-04-2001, 09:51 PM
Cliff Watson's Avatar
<font face="Verdana, Arial" size="2">Originally posted by jaam:
This is nice. I no longer get any audio analog channels. It just stopped woking. It still works on DTV both pc and ac3.</font>
Did you try reinstalling the accessDTV software including DX8?
Best Regards, Cliff
Digital Connection, LLC
cwatson53@home.com
Cliff Watson is offline
post #3 of 9 Old 05-04-2001, 10:14 PM
Rich4av's Avatar
jaam,
I have found that many DVD player applications (and there are others) replace Microsoft DirectX files WITHOUT ASKING. That has caused me a number of problems due to mixing DX6 and DX8 files, etc.
Now, when I install such applications, I immediately execute the DX 8a program from Microsoft from http://www.microsoft.com/directx/hom...ds/default.asp just to make sure everything is in synch.
Rich
Rich
Rich4av is offline
post #4 of 9 Old 05-04-2001, 10:48 PM - Thread Starter
jaam's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Cliff Watson:
</font>
Uninstalled AccessDTV .reinstalled it. reinstalled DX8.
No difference.
Joe
jaam is offline
post #5 of 9 Old 05-05-2001, 12:12 AM
Joe,
Did you install any other software/hardware around the time it stopped working?
Best Regards, Cliff
cwatson53@home.com
post #6 of 9 Old 05-05-2001, 06:19 AM - Thread Starter
jaam's Avatar
Joe,
</font>
I don't know exactly when it stopped working. I don't use NTSC all the time. It's a computer. I've installed software. Am I suppose to check accessDTV every time I do anything and document everything I do. I've already reinstalled my OS once this month because of this card for an error I was getting only to see a software update on the accessDTV site for just that error.
I like the card and as I've said The sound does work in DTV mode.
I installed Acrobat reader 5. Did that do it? I've installed a Sidewinder racing wheel. Did that do it?
Joe
jaam is offline
post #7 of 9 Old 05-05-2001, 10:38 PM
Joe,
It was a simple tech support question.
Best Regards, Cliff
cwatson53@home.com
post #8 of 9 Old 05-05-2001, 11:09 PM - Thread Starter
jaam's Avatar
Joe,
</font>
Ok,
Well, just to make sure. I format C: reinstalled WinME ,Directx8 radeon drivers 7075. When I wan installing the janus and the Saa7146 (From the CD)I again got the message that they were older than the ones already on the system. I chose NO to use the ones on the cd. It seems odd that the ones on the cd are older .
Anyway. I now have NTSC sound again. Geees.
I guess I must document everything I install and check to see what ever did that. Oh , well. at least the card is fine:-)
Joe
jaam is offline
post #9 of 9 Old 05-05-2001, 11:31 PM
â€I chose NO to use the ones on the cd. It seems odd that the ones on the cd are older .â€
You can answer yes or no, makes no difference, because the files that Windows is installing are not on the CD. They are WDM streaming drivers that are part of WinME and the problem is with Windows.
Best Regards, Cliff
cwatson53@home.com
Closed Thread Home Theater Computers
