Digital vs. Analog TVs - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 05-05-2001, 04:11 PM - Thread Starter
rorybbellows's Avatar
What's the difference. If two tv's are capable of displaying 800 lines of resolution and one is digital and one is analog and the source is my computer, how does the electronics of the tv(aside from the tube) make any difference?
I know most analog tv's don't have vga in, but many do have component in and there are a lot of vga to component adapters available now. So what am I gaining with a digital tv if my computer will always be handling the video processing? Is there some reason why I can't display the full resolution of the analog tv from my computer (eg 800x600)? Thanks.
rorybbellows is offline
post #2 of 3 Old 05-05-2001, 08:29 PM
Namlemez's Avatar
An analog TV with component input will only take 480i signals. It might have an internal scaler that would scale it up for 800 lines, but generally it will look very bad comparatively.
Cal Z.
Mits 65903 (65" widescreen HDTV)+ RCA DTC-100
and
Gateway Destination 27" (Princeton Arcadia based)+HTPC (Pentium II 400, 256mb, 20gb+9gb HD, Radeon LE, cybertainment tv tuner, asus dvd-rom, hercules game theater xp, Kenwood VR409 DTS receiver)
crz@andrew.cmu.edu
Namlemez is offline
post #3 of 3 Old 05-05-2001, 11:22 PM - Thread Starter
I don't understand the point of designing a tv with 800 lines resolution that will only accept 480i. There must be a way to take advantage of that resolution or the tv wouldn't be designed with that resolution.
Closed Thread Home Theater Computers
