YXY Hidden mode help? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 05-05-2001, 11:22 AM - Thread Starter
xcel's Avatar
Hi Kerry:
___You should see YXY as an icon in your system tray. Right click on the icon and select Show YXY. The hidden mode is to use Hot Keys for YXY control only. Wait until you have a few DVD’s under your belt and than go ahead and setup your YXY hot keys. By that time, you will have figured out how you want to use YXY exactly and you will have a real good idea as to what hot keys you want but how to set them up so as to not interfere with any other Hot Keys you may use in the future.
___Good Luck
___Wayne R. Gerdes
___Hunt Club Farms Landscaping Ltd.
___ xcel@midwest.idsonline.com
New E-Mail address for the time being ... waynegerdes@earthlink.net
xcel is offline
post #2 of 5 Old 05-05-2001, 12:11 PM
kdraper's Avatar
The right-Click option does not appear for YXY on my machine when running in Hidden mode. It does work however when running in minimized mode.
Running under w2k sp2beta.
Kerry
kdraper is offline
post #3 of 5 Old 05-05-2001, 12:35 PM - Thread Starter
xcel's Avatar
Hi Kerry:
___Download the latest YXY version 1.6. Both 1.6 and 1.6.18 (version 1.6.18 is the ATI player version) have this same capability. Right click on the system tray icon and choose show YXY. I am under Windows 2000 w/ SP2 right now as well.
___Good Luck
___Wayne R. Gerdes
[This message has been edited by xcel (edited 05-05-2001).]
xcel is offline
post #4 of 5 Old 05-05-2001, 10:33 PM
kdraper's Avatar
Ok I know this must be a dumb question but I cannot figure it out. I have set YXY to run in hidden mode at startup and now I cannot pull it up onto my desktop to change any settings. It is running in my toolbar but I cannot find an action that will make it active.
Kerry
kdraper is offline
post #5 of 5 Old 05-06-2001, 09:27 AM
kdraper's Avatar
Thanks for the info I am using 1.6 but no luck. The right-click function does not work when running in Hidden mode but just fine when minimized is selected. No big deal I can live with this.
Kerry
kdraper is offline
Closed Thread Home Theater Computers
