stability: Pentium3 or Pentium4? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 05-06-2001, 05:09 PM - Thread Starter
automagic's Avatar
I am about to put together a new system using xcel's recommended parts with an asus mb and a pentium3 1gig cpu. I notice that I could put together a machine with a 1.4gig pentium 4 for about the same money. Stability is paramount to me. Would stability take a hit with the pentium 4?
Thank you,
Paul
automagic is offline
post #2 of 6 Old 05-06-2001, 08:40 PM
xcel's Avatar
Hi Paul:
___Here is a few prices for you to consider on the P3 vs. P4 solution:
I815E ASUS CUSL2 ~ $120.00
I850 ASUS P4T for ~ $190.00 or a MSI 850 Pro for ~ $180.00 + ~ $20.00 for CRIMM’s
KT133A ASUS A7V ~ $123.00
PIII 1 GHz ~ $220.00
P4 1.5 GHz ~ $210.00
T-Bird 1.33 GHz ~ $210.00
256 MB Micron PC133 CL2 SDRAM ~ $91.00 for both the PIII and the T-Bird
256 MB Samsung PC800 RDRAM ~ $220.00
___The difference is ~ $180.00 USD in favor of the PIII solution. You should receive a performance increase of ~ 20% with the P4 over the PIII at the frequencies posted above. You will lose ~ 5% using a P4 vs. a T-Bird at the frequencies in the above comparison although I do not truly recommend the AMD/VIA solution for HTPC use as you probably already know … The CPU F/HS’s required for the P4 and the T-Birds needs to be a bit more robust (higher dB output) and I did not go into the specialized ATX12V PS and possible case configuration (I/O shields and form factors are a bit different) so make sure you are aware of this in your pricing and usability model as well.
___As for the stability, I would suspect the PIII on the CUSL2 is the most stable board but I have no definitive proof of this in my experiences. Both the A7V133 and the ASUS CUSL2 in my household run 24/7 and both perform (with both performance and stability in mind) magnificently. The Sharky Extreme Review of the ASUS P4T and the MSI 850 Pro linked above made mention of the fact that these 2 P4 boards may not have crashed once during their testing at std. FSB’s. There is a PCI bandwidth bug plaguing the I850 P4 chipset but there is an HTPC forum member that uses a HiPix or an accessDTV without trouble on the I850 himself.
___Good Luck
___Wayne R. Gerdes
___Hunt Club Farms Landscaping Ltd.
___ xcel@midwest.idsonline.com
New E-Mail address for the time being ... waynegerdes@earthlink.net
[This message has been edited by xcel (edited 05-07-2001).]
xcel is offline
post #3 of 6 Old 05-06-2001, 09:31 PM
Desertfox's Avatar
Is there something I miss here ? I thought the P-4 mobo's need a different Power Supply ? Wouldn't that be another expense for a P-4 system !
***Stop DFAST, HDCP and Boycott JVC*** HTPC1: P-III 800Mhz EB, 256MB PC133 SDRAM, ASUS CUSL2 Mobo,Telemann HiPix HDTV PCI card, Geforce 2 GTS 32MB DDR, Creative DVD-RAM, Creative Soundblaster Platinum 5.1 Dolby Digital, IBM 45GB 7200rpm HD, SuperMicro 750 FullTower with 6 fans, Cable Modem, Mitsubishi Diamond Pro 2040u (22")
[This message has been edited by Desertfox (edited 05-06-2001).]
Jens Wellmann
President
PC DTV Technologies, LLC
Desertfox is offline
post #4 of 6 Old 05-06-2001, 09:33 PM
Tony Lai's Avatar
Annecdotal evidence...
Using a pIV-1.4Gig on an Intel DB50 board and Adaptec u160 with a 10,000rpm drive and a gf2 GTS Ultra - utterly stable and insanely fast under Win2000... DVD's play ok too :-)
T.
IntelInside?
CyrixInstead:-P
AuthenticAMD!
"From the depths of winter I finally learned that within me lay an invincible summer..." a.c.
Tony Lai is offline
post #5 of 6 Old 05-06-2001, 09:36 PM
xcel's Avatar
Hi Guys:
___And the above is edited with links …
___Good Luck
___Wayne R. Gerdes
xcel is offline
post #6 of 6 Old 05-07-2001, 04:19 AM - Thread Starter
automagic's Avatar
Thanks Xcel and all,
I have been using a 1.2 gig tbird with a kt133a mb and gts ultra video and have not been impressed with stability for home theater. It is great for fps games however. I have decided to go with the p3. Thanks to all for their input.
Paul
Closed Thread Home Theater Computers
