WinTV-D Data Capture Problems Documented - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 05-05-2001, 11:46 AM - Thread Starter
BHeld's Avatar
Well today I tried every manner of installing the three files needed for getting dtvCapture to work. Here are the glitches I'm encountering.
1) When following the install order as prescribed I loose my digital channels after the dtvupdate install. The WinTV2000 screen is blue and diags show that the channels aren't even being tuned.
2) If I install in differenct sequences I can get the final WinTV2000 app to still tune the channels however everytime you start WinTV2000 the video is in black and white until you change the channel at least once. Additionally tuning multicast channels was not very reliable.
3) No matter which of the above is used, when I go to start dtvcap.exe I get an error dialog:
"A Device Attached to the System is not Functioning"
.... followed by another error dialog box:
"Error Starting Program dtvcap.exe is linked to missing export HCWPSIP.DLL:HcWPsipGetSystemPids"
So I'm shelving the whole concept for now unless someone has definate workarounds for these specific errors.
Bob Held
WinME, PIII 866mhz, 815e Chipset, 256MB, Radeon AIW, WinTV-D & DirectX 8
BHeld is offline
post #2 of 2 Old 05-07-2001, 06:50 AM - Thread Starter
BHeld's Avatar
Refreshing since as a weekend post it might have been missed.
Bob
BHeld is offline
Closed Thread Home Theater Computers
