Comparison of HDTV cards - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 05-07-2001, 10:03 PM - Thread Starter
Will Davis's Avatar
Has anyone compared the Wintv-hd to the new Accesstv card? I am in
the market for a HDTV card and I don't want to make a big mistake
in my choice. Has anyone used both cards in thier HTPC? I read in a post that Wintv-hd can demodulate digital cable 64 and 256
QAM. Can the Accesstv card demodulate digital cable? Finally, is
there any software conflict if I use a capture card and dtv for
delacing between dtv and the HDTV cards?
Thanks for your replys.
Will D. Davis
Will D. Davis
Will Davis is offline
post #2 of 3 Old 05-07-2001, 10:18 PM
JKohn's Avatar
I had a WinTV-HD at one point, and replaced it with an accessDTV. Overall, the accessDTV and its software seem to be more stable than the WinTV-HD. Channel-changing seems faster, too.
The ATSC tuner in the WinTV-HD is supposedly capable of decoding QAM, but I don't think the Hauppauge software supports that yet. I believe the accessDTV can decode QAM (assuming it's unencrypted), but I haven't tried that. Maybe Cliff W can comment on this capability.
The big difference between the two is recording capabilities. Right now, the WinTV-HD has no recording at all. It remains to be seen what they will offer in future updates, but my guess is at best it will be on the level of what the HiPix offers.
The accessDTV, on the other hand, offers recording out of the box, and can also pause live TV. It has an optional program guide that can be used to schedule recordings, but you can also schedule manual recordings. It's still missing some functionality that the set-top PVR devices include, but it's the only HDTV time-shifting device you can buy. If you want to add HDTV to your HTPC and you want recording capability, the accessDTV is the way to go.
Jeff
JKohn is offline
post #3 of 3 Old 05-07-2001, 10:46 PM - Thread Starter
Will Davis's Avatar
Thanks Jeff for your very quick and informative reply. This
forum is the best.
Will D. Davis
Will D. Davis
Closed Thread Home Theater Computers
