What the best custom HTPC resolution for Q1271? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 05-07-2001, 04:55 PM - Thread Starter
badams's Avatar
What's the experiences here by 1271 owners?
badams is offline
post #2 of 4 Old 05-07-2001, 05:04 PM
Brian Hampton's Avatar
Quoted: 584 Post(s)
Liked: 311
HI,
I've seen others state the best resolution for a 12xx projector is 800x600. Personally I like 720x480 as this is the actual resolution of DVD's and no scaling is required.
But, I only use my 1271 for DVD's so I can't comment on good resolutions for anything else.
Good Luck,
Brian
Brian Hampton is offline
post #3 of 4 Old 05-07-2001, 05:57 PM
JackB's Avatar
Quoted: 538 Post(s)
Liked: 98
I run mine at 1152x864 and it looks as good as HBO HD 1080i with PowerDVD.
Jack
Jack
JackB is online now
post #4 of 4 Old 05-08-2001, 09:31 PM
budiman's Avatar
I have a 1272, but I believe it doesn't differ that much vs. 1271.
Depending on screen size (and how you optimize it), I usually do a horizontal stripes and vertical stripes pattern. If the resolution with which that pattern is displayed can resolve the alternating stripes, then it's good enough. Try to go up in resolution until you hit the non-resolvable region.
My 1272 can resolve 1280x720 @ 72Hz, so I stick with that. YMMV. 720x480 is good as well since software DVD player won't do any scaling, so it's native, but I can still see scanlines with 480. My setting for cannot see scanlines would be around 660 or so (800x600 still can see a bit of scanlines).
Ciao.
Muljadi Budiman.
Ciao.
Muljadi Budiman
Ciao.
Muljadi Budiman
budiman is offline
Closed Thread Home Theater Computers
