How use Nero to put 880MB avi on (2) CDs? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 05-08-2001, 04:55 PM - Thread Starter
Kristi's Avatar
I'm a newbie at burning. Just got AOpen CRW1232A which came with Nero5.0, now updated to 5518. I have done single CD burns that work and play fine. Now wanting to get an 812mb avi off my HD, in a playable form. Can I use Nero to get it to "bridge" (is that the right term?) across multiple CDs, or do I need to break it apart first, and what program would I use for that?
tia
Kristi
MSI K7T Turbo, Duron 800, 256mb cl2 Crucial, Radeon LE, AOpen CRW1232A, Toshiba 1502 DVD, Hoontech XG sound card, ATI TV Wonder, etc!
Kristi
Kristi is offline
post #2 of 3 Old 05-08-2001, 05:46 PM
mcmillan's Avatar
I'm not sure what Nero does in this situation, but you can easily break the file (at your desired point)using virtualdub.
mcmillan is offline
post #3 of 3 Old 05-08-2001, 07:08 PM
theREALmacdaddy's Avatar
Once the file is split; you can just drag it over (use the wizard and create a new CD-ROM)and burn. If you are making a DivX, you might want to include an auto-launcher (that enables the codec to be installed if it is not already)...
-macdaddy
visit www.theHarangue.com
-macdaddy
theREALmacdaddy is offline
Closed Thread Home Theater Computers
