New HTPC, can't get digital audio with ATI player - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 05-23-2001, 04:35 PM - Thread Starter
bnewton's Avatar
I know I have read info on this in the past, and I have read the FAQ, but I'm still somewhat at a loss. I'm thinking my ATI player may be a lame version or something.
I have a 1GHz P3, Radeon 64MB, and Audiophile 24/96. When I use WinDVD I get good (not great) video and working digital audio to my Rotel RSP-985. When I use the ATI player I get excellent video, but can only get analog audio. SPDIF won't work.
I attempted to download and install the latest ATI DVD player, but was stymied when it wanted the number off the CD. I entered that, but it wouldn't take it.
The version I currently have seems to be 7.1 or something, the same as the ATI tools.
Any thoughts?
By the way, the HTPC is awesome with my NEC GP-3000 projector. dScaler and DVD output are so superior to what I have before, I can hardly stand it. I can hardly wait until I get my NEC XG-1100 running...
Barry
http://www.newton.org/theater.html
bnewton is offline
post #2 of 5 Old 05-23-2001, 05:09 PM
jcalvert's Avatar
Hope some of this info helps:
From the Rage3D site -
Aparently a number of people have had problems with the installation of the new ATI DVD Player that is availible for download. The main problem is making the install detect that you have the right CD. Here is a fix:
1)Browse the contents of the CD to \\install\\mmcdvd\\dvd\\
2)Look for the file dvd.dll and RIGHT-CLICK on it and choose properties.
3)In the window that opens up, click on the versions tab. Write the very top file version number. (eg. 7.0.0.23)
4)Enter the coresponding CD-KEY number from this list.
5)Should install properly now.
ATI DD w/ DVDGenie -
http://www.avsforum.com/ubb/Forum12/HTML/008774.html
http://www.avsforum.com/ubb/Forum12/HTML/008956.html
jcalvert is offline
post #3 of 5 Old 05-24-2001, 07:09 AM - Thread Starter
bnewton's Avatar
Thanks for the reply. I'll try this out as soon as I get home...
Barry
bnewton is offline
post #4 of 5 Old 05-24-2001, 10:32 AM
otaku's Avatar
Once you get the ATI 4.1 DVD player intstalled, use DVDGenie, following the radeon instructions at www.dtvmax.com to enable SPDIF output.
I just built a system very similar to yours (with 32MB DDR radeon and a crystal audio card), and got SPDIF output going last night.
Now I just need to get dScaler and PowerDVD working...
DB.
otaku is offline
post #5 of 5 Old 05-25-2001, 01:35 AM
power's Avatar
i HAD problems with the ATI MMC 4.1 dvd player but i now have the required category 4 setting for the Radeon and DD passthrough; just follow XCEL's instructions as to the proper DVDGenie settings for the Cinemaster (ATI) tab and you should enable SPDIF out. Let us know how everything goes. Good luck
Serge
<FONT size="1">Parasound AVC 1800
B&K AV 5000 II
Monitor Audio Silver 5's, silver center and silver 3's(rears)
HSU VTF 2
Toshiba DVD
Mitsubishi LVP X70 FPTV
Dalite High Contrast Da-mat 16:9 grey screen
RCA DTC 100
HTPC consisting of Duron 750, AOpen motherboard, Radeon LE video and Turtle Beach Santa Cruz sound</FONT s>
Serge Breton
htauthority.com
Home Theater Authority
power is offline
Closed Thread Home Theater Computers
