hipix, sony projector and gforce help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 05-25-2001, 09:57 PM - Thread Starter
Stuigi's Avatar
can someone who has this type of setup email their telephone number so that I may pick their brain. For some reason when I try the resolutions that all here speak about, I cant get a pix and I dont know whats wrong. With the gforce card looping into the hipix, and the hipix connected to the projector through the vga to 5 bnc cord, I can see the pc screen when the projector is in computer mode. That works. If I play a file from the hipix and then switch my projector to rgb mode, the pix is magnificent. when in that mode though if i click the moue to get back to my desktop, the screen goes blank. I have tried many different combos with the same result. Is this a win 2k issue or am I doing something a bit wacky. Your help would be appreciated as I know that I am very close. I just need someone to hold my hand
There is enough sadness in the world. Make someone smile today!
Stuigi is offline
post #2 of 3 Old 05-25-2001, 10:33 PM
Check your email.
***Stop DFAST, HDCP and Boycott JVC*** <FONT size="1"> HTPC1: P-III 800Mhz EB, 256MB PC133 SDRAM, ASUS CUSL2 Mobo,Telemann HiPix HDTV PCI card, Geforce 2 GTS 32MB DDR, Creative DVD-RAM, Creative Soundblaster Platinum 5.1 Dolby Digital, IBM 45GB 7200rpm HD, SuperMicro 750 FullTower with 6 fans, Cable Modem, Mitsubishi Diamond Pro 2040u (22")</FONT s>
Desertfox is offline
post #3 of 3 Old 05-26-2001, 01:31 AM - Thread Starter
Stuigi's Avatar
after countless hours of trying to get my win 2k desktop to display in rgb mode, I was able to do so in 640X480. any other resolution would not work. Is there a way to make my desktop larger, so that my icons and applications would show up smaller
Stuigi is offline
Closed Thread Home Theater Computers
