Radeon users: any artifacts watching "The Haunting"? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 05-27-2001, 06:53 AM - Thread Starter
mburnstein's Avatar
I have the Radeon LE running Win 98SE,ATI 7.1 MMC with DVD Genie 4.00 configured Region:1
Decode Setting: ATI Rage 128 (this sets performance class to 4 for radeon)
Sample Rate: 48000
DeInterlacing: Force Weave (forces progressive scan, best for movies)Hardware Optimization: yes
3:2 Pulldown: (May be backwards, see below) Leave unchecked to enable
Apply Settings retroactively: yes
Surface Flip Mode: default for Cinemaster 2.0
Surface Flip Position: default
Sound Compression Mode: default
Downmix Audio to: DPL
AC3 DownSample Mode: default
AC3 SP/DIF Audio Type: 1-Enable in GUI
AC3 SP/DIF Out Mode: 04 (for SB Live)
Dynamic Audio Range Compensation: low 0% high 0%
Dialog Normalization: yes
Require Color Key: yes
Use LFE decoding: yes
Enable SP/DIF: yes
When watching "The Haunting" on my xg 135 FP with the 4:3 screen at 1024 x 768 @72Hz and the widescreen locked option checked in DVD Genie 4.00 to maintain anamorphic display of this disc on a 750 Athlon Marquee DC HTPC,
I noticed several artifacts:
The opening scene panning the outside of the apartment building shows small diagonal lines at the edges of the building and the outside windows, brick lines and story levels. The scene showing the outside gate to the mansion has horizontal artifacts superimposed at the gate. The inside mansion scenes showing the stairs has horizontal lines apparent as the stairs are panned upward. Also panning the multicolored carpet causes some "swarm of mosquitos" blurring artifacts. And the bedroom scene of the first guest shows artifacts, like shimmering around the borders of the round leaded glass windows. Any idea what is causing this?
mark
mark
mburnstein is offline
post #2 of 2 Old 05-27-2001, 07:22 AM
trbarry's Avatar
Mark -
I don't have a Radeo though I've heard of the backwards check box.
But the artifacts you describe could all be typical of using a video deinterlace method and _not_ doing 3:2 pulldown removal.
- Tom
Getting started:
HTPC FAQ , DScaler , Xcel's Links .
Why don't we power our electric cars from greener, cheaper Liquid Fluoride Thorium Reactors?
Tom Barry - Find my video filters at www.trbarry.com
trbarry is offline
Closed Thread Home Theater Computers
