Powerful Android Streaming Box Suggestions - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 09-27-2017, 05:44 AM - Thread Starter
cctaylor88's Avatar
Quoted: 13 Post(s)
Exclamation Powerful Android Streaming Box Suggestions
I want a fast, snappy, and intuitive android box to stream and cast media. But I will never ever ever use it to "game." From what I can gather the Nvidia Shield is one of, if not the most powerful devices to stream media, however I know its geared towards gaming and even ships with a controller that I would probably just leave in its packaging as the unit also ships with a remote.
Are there any options that are just as powerful as the Shield that don't utilize "gaming" or controllers?
1. The box has to be able to download and utilize apps seamlessly (no tricks or installation of third party backdoor or sideloading software).
2. Has to run Kodi as close to flawless as possible (for example no sideloading etc, just want to be able to download and utilize Kodi)
3. Does the Shield run Kodi as any PC would? Are there any limitations/restrictions? Can I run any old repository just like I would be able to on a PC?
4. Is there anything comparable to the Shield in terms of speed?
5. If I do go with the Nvidia Shield, I don't have access to hardline ethernet in the room in which it'll be used. Will it still be noticeably quicker than my AppleTV as an example?
6. Can it utilize Chromecast? As in, if I want to stream (mirror?) a video from my phone/laptop to the Shield, is it simple?
7. ELI5 the difference between the Nvidia Shield and the Nvidia Shield Pro. Is the Pro actually faster, or does it just have more storage?
CPU: Intel i7 6700k
GPU: EVGA 1080 FTW
Motherboard: Gigabyte G1 Gaming 7
Cooler: Corsair Hydro Series H115i
Case: NZXT H440 Red/Black
Monitor: LG 34" UC88-B
cctaylor88 is offline
post #2 of 5 Old 09-27-2017, 06:27 AM
bryansj's Avatar
Quoted: 1421 Post(s)
Liked: 645
There is a new 16GB Shield that only ships with the remote and no controller for $179.
The Shield has GoogleCast built in.
I'd look in here http://www.avsforum.com/forum/39-net...ent-streaming/ since this is supposed to be a HTPC forum.
bryansj is online now
post #3 of 5 Old 09-27-2017, 07:11 AM - Thread Starter
cctaylor88's Avatar
Quoted: 13 Post(s)
Thank you very much
post #4 of 5 Old 09-27-2017, 07:16 AM - Thread Starter
cctaylor88's Avatar
Quoted: 13 Post(s)
Thank you very much
post #5 of 5 Old 09-27-2017, 01:19 PM
TornadoTJ's Avatar
Quoted: 1723 Post(s)
Liked: 539
The answer to everything there is "yes".
As far as hardwiring, although the wifi in the Shield is very fast, you might consider powerline or MOCA alternatives.
TornadoTJ is offline
Reply Home Theater Computers
