sharing sub/sharing digital cable - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 06-09-2001, 05:04 AM - Thread Starter
Hugh Magoo's Avatar
(IMNEW)
Wondering if I will be able to connect HTPC to subwoofer concurrently with HT system. I currently run an rca jack from receiver to sub and y-split it and connect to both inputs. Would I be able to utilitze both jacks for two seperate signals at the same time?
Also will most likely be getting Time Warner digital cable & Roadrunner Cable Modem. Are there any solutions to accessing the digital cable with an HTPC?
Hope I am not excessively newbish.
Hugh.
*_building 1.4ghz T-bird,RAID,Radeon 64,looking for good Mobo(waiting for A7V266)(Have you heard about nForce?)
Hugh Magoo is offline
post #2 of 3 Old 06-09-2001, 06:57 AM
Phat Phreddy's Avatar
I think the theory on the sub should be OK but why ?? Just route all HTPC sound via receiver and then go HTPC -> Receiver -> Speakers including sub... If you need game sound link both analogue outs as well as digital out...
There are DVB and DVT cards out there.. I must say I saw a DV(B??) card run through dScaler and it was a pretty amazing picture almost DVD quality to my (amateur) eyes... I am also assuming you could use S-Video out to PC to dScaler without any problem...
PhatPhreddy@Bigfoot.com
HTPC without using windows... GUI Front Ends for Home Theater
[This message has been edited by Phat Phreddy (edited 06-09-2001).]
Phat Phreddy is offline
post #3 of 3 Old 06-09-2001, 03:45 PM - Thread Starter
Hugh Magoo's Avatar
thanks,
I'll definitely look into fine tuning my Digital cable through my HTPC.
I think the SUB will work best if I run HTPC through receiver like you said. Thanks for your response.
Hugh
Closed Thread Home Theater Computers
