Projection unit for HT and Lecture - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 06-08-2001, 02:00 PM - Thread Starter
Ajlift's Avatar
I am planning a lecture to about 30 people in a moderately sized conference room. I need to purchase a projection device which I probably will use only occasionally. The lecture will be on my laptop and the more compact the device, the better.
I was thinking of whether it would be possible to spend some extra money to get a unit that would also be great to use with my HTPC. I'm really enjoying watching high definition on my computer monitor but would love a bigger picture in my living room.
Any input from the forum would be greatly appreciated.
Alan
Ajlift is offline
post #2 of 2 Old 06-09-2001, 04:29 PM
anyseong's Avatar
Hi, Alan
In my opinion, one of the most suitable pjs for you will be NEC MultiSync LT150.
Compact, only 3.1LB, XGA-resolution, high 800:1 contrast, 800 ANSI lumen, a variety of color controls, full HDTV and EDTV compatibility..., you will never disapointed with that small beauty with DLP heart. Alternate indication is Infocus LP 350 with DVI interface also DLP and similar spec.
If you want more details visit"www.projectorcentral.com".
Hope to be help.
Yong.
anyseong is offline
Closed Thread Home Theater Computers
