HTPC Newbie Question: 1080p OTA HDTV options? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 06-10-2001, 05:23 AM - Thread Starter
amillians's Avatar
I've tried to get a straight answer on this via researching the forum FAQs, but I'm new to HTPCs, so maybe I'm missing something...maybe I'm a little slow...
Putting together a new home theater, which will feature a Sony G90, and I want to know what my options are for generating true 1920 x 1080 1080p from 1080i OTA HDTV. In other words, can I use one of the HDTV tuner cards in conjunction with something to replicate a Faroudja 5000?
The outboard scaler route is flawed...the F5000 is big bucks, the Vigatec outputs about 1440 x 1080 1080p from 1080i (too soft) and the Rock isn't there yet (I think they plan on something akin to what I want, but until I see it, I have to politely pass).
I basically want to have an HTPC for DVD and HDTV, video routed directly to the G90 and audio routed directly to my Lexicon MC-1...I know the DVD part of the equation is there, and I know that the 720p/1080i OTA HDTV part of the equation is there, but what about the 1080p OTA HDTV part of the equation? Please stop me from buying a F5000! http://www.avsforum.com/ubb/smile.gif
Alex
Alex doesn't live here anymore
amillians is offline
post #2 of 2 Old 06-10-2001, 06:17 AM
work permit's Avatar
Quoted: 12 Post(s)
I'm not sure the pci bus even has the bandwidth to do what you want. you would need the tuner card to do it locally, as you know wintv-d, et al don't provide this
Alex
Alex
work permit is offline
Closed Thread Home Theater Computers
