WinDVD white "frame" - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 06-09-2001, 02:41 PM - Thread Starter
Dave T's Avatar
I have a thin, bright white frame around the outside edge of my 16x9 screen, when playing movies with WinDVD. I'm using a DILA, at a resolution of 1360x768. The frame is always around the edge of the display area, regardless of the aspect ratio of the movie.
Anyone know what this is?
- Dave
Dave T is offline
post #2 of 3 Old 06-09-2001, 11:15 PM
siwilson's Avatar
This may or may not be related, but I found that if you have WinDVD set to open in full screen and then specify maximised in the command that launches it you get this problem. For instance I use Girder to launch WinDVD and girder was set for maximize. Igto the white border. When I set Girder to launch WinDVD in 'normal' the whit border went away.
you might want to check that whichever way you launch WinDVD you say 'normal'
Hope this helps http://www.avsforum.com/ubb/smile.gif
Simon Wilson
My Naff Home Page
Simon Wilson
My Naff Home Page
siwilson is offline
post #3 of 3 Old 06-10-2001, 07:56 AM - Thread Starter
Dave T's Avatar
Thanks, Simon! I'll give that a try.
Dave T is offline
Closed Thread Home Theater Computers
