WinDVD 2.6 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 06-10-2001, 08:06 AM - Thread Starter
mannyqg's Avatar
Hi,
Goin thru postings here, I bought WinDVD 2.6 from a link provided by somebody in this forum. I uninstalled my old one and installed this version. However, the SPDIF out was grayed out so there was no way to get DD/DTS sound which can be done by my older version. Is there a way to fix this? The seller will not entertain any refunds, so I had to reinstall my older version.
Manny
mannyqg is offline
post #2 of 4 Old 06-10-2001, 12:06 PM
xcel's Avatar
Hi Manny:
___One word, Blight’s excellent SW DVD player utility called DVD Genie 4.0 . Enable S/PDIF with the WinDVD tab --> more options --> Audio Mode --> SP/DIF. That is if your sound card and its drivers are AC-3 pass-thru/DTS capable.
___Good Luck
___Wayne R. Gerdes
___Hunt Club Farms Landscaping Ltd.
___ xcel@midwest.idsonline.com
New E-Mail address for the time being ... waynegerdes@earthlink.net
xcel is offline
post #3 of 4 Old 06-10-2001, 02:46 PM
CCLAY's Avatar
Hey Manny,
Was that the link I posted to Buystarnow.com(or something similar) for $16.99? It was the 2 channel version, but with DD and DTS "pass thru", right?
I was going to get that disc, but with the new WDVD3 around the corner.......
I hope you get it working.
And if you don't, here I am for bashing. http://www.avsforum.com/ubb/biggrin.gif
Chris
My Home Theater is a work in progress.
CCLAY is offline
post #4 of 4 Old 06-10-2001, 09:00 PM
spacecat's Avatar
windvd 2.6 is an upgrade i upgraded mine from 2.3 to 2.6
spdif works perfectly dd/dts.
must be another problem
spacecat is offline
Closed Thread Home Theater Computers
