Help me get started with my HTPC - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 06-23-2001, 07:57 AM - Thread Starter
Polaris Freak's Avatar
Just ordered a NEC CRT from AVS and instead of buying their scaler decided I wanted to do an HTPC. I am building my dedicated ht for use only with DVD, DirectTV and VHS(have hundreds of them might as well use them.) Do I need the scaler to get these into an RGB connection or can I just run them all into my avr? If so is there just a simple device that will do this without the $1500 price tag? I have a friend who owns a comp store and will get me all the parts at cost. How much chip and processor do I need? What cards do I need if I never care to record or play antenna based signals? Any help would be appreciated. (Pardon my newbieness if I asked a dumb question)
"..go on, skin that smokewagon!"
Polaris Freak is offline
post #2 of 2 Old 06-23-2001, 08:15 AM
Namlemez's Avatar
This is something that is covered quite frequently, you will learn the most by simply searching the forum.
Someone recently asked this question and this link was given.
Cal Z.
Mits 65903 (65" widescreen HDTV)+ RCA DTC-100
and
Gateway Destination 27" (Princeton Arcadia based)+HTPC (Pentium II 400, 256mb, 20gb+9gb HD, Radeon LE, cybertainment tv tuner, asus dvd-rom, hercules game theater xp, Kenwood VR409 DTS receiver)
crz@andrew.cmu.edu
Namlemez is offline
Closed Thread Home Theater Computers
