Zoom Player 1.71 beta 1 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 07-29-2001, 01:01 PM - Thread Starter
Blight's Avatar
Ok, let me just say that DirectShow isn't very friendly when trying to manipulate individual filters.
Trying to add support for multiple audio-tracks was rather painful. Hopefully it does work though, give it a shot.
Here are the rest of the changes:
Code:
 * Support for two or more selectable audio streams.  The default
   DirectSound device is always the initially played audio, but
   you can now using the right-click menu, you can select any other
   DirectSound streams.
 * Restructured the Information dialog.  This new dialog gives
   dynamic information about frames dropped in the renderer and
   the actual playback FPS as achieved by the renderer.
 * Enabling Multiple Instances will no longer cause the registry
   settings to be reset.
 * Play List is no longer remembered by default (some people found
   it annoying), you can re-enable this feature through the options.
   This should also help with CD-Based playback (when the zoom
   player executable is on the actual CD).
 * The presets dialog will now appear screen-centered when docking
   is disabled.
 * New "Mute" ON/OFF function, accessible by pressing Ctrl+"M".
   Can also be made into a button by through the skinning functions.
 * You can now have the mouse cursor moved automatically to the bottom
   right corner of the screen when going into Fullscreen/Zoom mode.
   This is useful as windows tend to pop the mouse cursor every
   once in a while.
 * The DivX dialog function will now open the OpenDivX dialog as well.
 * Disabled some useless OSD messages such as the pause/play when opening
   a file with auto-play enabled and all messages in between a Play List
   next file load.
Get it here
Webmaster
www.inmatrix.com
Yaron Gur
Zoom Player . Lead Developer
Blight is offline
Closed Thread Home Theater Computers
