Can Radeon be set for D'iLA's sweetspot resolution? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 08-23-2001, 12:03 PM - Thread Starter
AudioFileZ's Avatar
How do you adjust the Radeon card for native D'iLA resolution? On the menu selection I do not see a resolution that looks right for D'iLA's native sweetspot. Any info appreciated.
AudioFileZ is offline
post #2 of 6 Old 08-23-2001, 01:53 PM
brian_vh's Avatar
Liked: 34
Load the 7140 drivers (works fine with custom resolutions), or the 7075 that come with it. Some driver versions I tried wouldn't allow for custom resolutions to show up.
Then load powerstrip 3 beta - latest version from the web.
Add a custom resolution, such as 1360x1024 and 1360x768 within powerstrip. Reboot your machine, then select the resolution on the Display properties slider.
Remember to add custom resolutions after each ATI driver update, it removes them from the list.
Should work fine.
Our Home Theater - http://www.fatbulldog.com
Last updated 6/1/01
- Denon X6300H 7.1.2 currently - Oppo 203 - JVC RS500 calibrated by ChadB. for r.709 BD, BT.2020 HDR using custom gamma - Paradigm Signature Series v3, Paradigm surrounds - Stewart powered 120" 16x9 Firehawk G3 1.3 gain - dedicated room - Member since this site started... AVSForum rules
brian_vh is offline
post #3 of 6 Old 08-23-2001, 03:24 PM
GilR's Avatar
brian_vh
When I try 1360x1024 I get a scrolling desktop that moves left and right with my mouse. When I use 1368x768 I get a chopped/split desktop. The only one I can get is 1280x1024.
Any help on that? I am using 7093 drivers but never worked even with the original drivers.
Rgds
Gil
GilR is offline
post #4 of 6 Old 08-23-2001, 04:02 PM
Chris Carollo's Avatar
You need to explicitly tell the radeon card what monitor you're using, since it can't recognize the projector.
Turn off plug-n-play support, then explicitly set the monitor to a ViewSonic G790 (many monitors will work, but this is was I use). Remove all custom resolutions with powerstrip, then reboot. Add the custom resolution, but don't switch to the resolution. Reboot. Set to the custom resolution, and you should be all set.
Chris Carollo is offline
post #5 of 6 Old 08-23-2001, 06:04 PM
GilR's Avatar
Chris,
That was the ticket I was looking for!! Thanks much. I had the feeling it was a monitor file. I tried one or two with no luck but your worked great. Now the ati player works nice but I get some white horizontal line moving up and down every so often. Ever see this? I tried WinDVD and its the same. May be some other PJ adjustment. I have Dilard.
Any suggestions?
Thanks again.
Gil
GilR is offline
post #6 of 6 Old 08-24-2001, 07:55 AM
Morbius's Avatar
Gil,
Although the JVC D-ILA can sync to the resolution of any of
a number of monitors - if you want to drive the D-ILA at its
native resolution - and effectively bypass the internal
scaler - i.e. "pixel perfect" resolution - then Brian
gave you the proper advice.
Greg
Dr. Gregory Greenman
Physicist
Morbius is offline
Closed Thread Home Theater Computers
