Newbie question on Radeon le setup - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 09-13-2001, 07:39 AM - Thread Starter
tuffguy3's Avatar
I'm trying to get custom T&R's with my radeon Le and powerstrip 3.0 but I think my monitor wont display the resolutions. If I uninstall my monitor the custom T&R's work. I'm using Win2k with sevice pack 2. What I'm I missing ? Is there a monitor type I should be using?
Thanks for the help
Tuffguy3
tuffguy3 is offline
post #2 of 2 Old 09-13-2001, 09:22 PM
xcel's Avatar
Hi Tuffguy3:
___A few things … First off, you should use a Windows 2000 ATI driver known to offer custom T&R’s. Not all do but I know the 3102’s and 3116’s offer this capability. I have also read of both the 3124 and 3224’s having custom T&R capability as well but with the imminent release of Windows XP Pro, I am not using Windows 2000 any more to tell you for sure. As far as your monitor inf, choose the Sony GDM-W900 and Windows will allow just about anything your std. monitor can display via PowerStrip or ATI’s mode maker. After you select a custom T&R, you do not need to reboot immediately but select all of those you think you will be using and only afterwards, reboot. After you reboot, you will have access to all the custom T&R’s you will need for a successful custom T&R display to your PC monitor of choice.
___For a driver of choice link, hit Rage3D’s Driver download pages.
___Good Luck
___Wayne R. Gerdes
___Hunt Club Farms Landscaping Ltd.
___ Waynegerdes@earthlink.net
xcel is offline
Closed Thread Home Theater Computers
