Help me get DTS & DD with M-Audio 24/96 and Power DVD - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 09-29-2001, 07:39 PM - Thread Starter
cdissmore's Avatar
I'm working with my brand-new P4 HTPC, and running PowerDVD with the M-Audio 24/96 Audiophile card, using the SPDIF out. For some reason, I only seem to be getting PCM output, not DTS or DD.
For example, when I load the U-571 DVD and select 5.1 I get PCM Pro-logic over the SPDIF, but when I select DTS I get silence.
I've tried other DVD's and have PCM audio only.
Help?
Carey Dissmore
Carey Dissmore
cdissmore is offline
post #2 of 5 Old 09-29-2001, 08:26 PM
madcowz's Avatar
What OS are you running? Have you updated the drivers?
madcowz is offline
post #3 of 5 Old 09-29-2001, 08:33 PM
Cliff Watson's Avatar
Carey,
You need to set the sound output device to "WaveOut S/PDIF" in the Sounds and Multimedia (Windows Control Panel). Also select S/PDIF for the audio output in PowerDVD.
M audio Control Panel setup instructions are in the Cliff Notes at www.digitalconnection.com/Support/cliffnotes_8.htm
Best Regards, Cliff
Digital Connection, LLC
cwatson53@home.com
[This message has been edited by Cliff Watson (edited 09-29-2001).]
Cliff Watson is offline
post #4 of 5 Old 09-29-2001, 08:40 PM
xcel's Avatar
Hi Cary:
___To add to what Cliff posted … If you are using Windows 2000, you must switch the drivers setup for DD/DTS to Professional Non-Audio in the S/PDIF tab of the M-Audio control panel. You will again need to switch back to Consumer for PCM. Under Millennium/Win98 SE, the drivers are auto-switching thanks to Cliff’s hand holding with Midiman themselves but under 2000, they aren’t.
___Good Luck
___Wayne R. Gerdes
___Hunt Club Farms Landscaping Ltd.
___ Waynegerdes@earthlink.net
xcel is offline
post #5 of 5 Old 09-29-2001, 11:53 PM - Thread Starter
cdissmore's Avatar
Wow, thanks guys. It just figures that two of the people who have had the most influence on my decisions re: the components for this HTPC would get me over my first hurdle!
Wayne, yours from all of your great posts and Cliff (okay, so I ordered my stuff from Kei) from my primary vendor.
Thanks again, I'm up-n-running. BTW- now I'm about to install the Access DTV, albeit with the small bundled antenna for now. I've yet to purchase a big one for the attic...still finishing the theatre in the basement!
All the best,
Carey Dissmore
BTW- I'm running WinME with all of the updates. My primary reason for choosing this was the supposedly better Radeon drivers...although coming from several other Win 2000 machines (in my office) I gotta say I already miss the robustness and stability. I do have a free upgrade to XP coming, so I'll probably do that.
[This message has been edited by cdissmore (edited 09-30-2001).]
Carey Dissmore
Closed Thread Home Theater Computers
