cyberlink claudfx.ax and dshow auto graph and why it loads multiple times? - AVS Forum | Home Theater Discussions And Reviews
Old 12-18-2003, 12:45 PM - Thread Starter
AndyIEG's Avatar
If i set the cyberlink dshow effect filter claudfx.ax to merit 00800001 wich means it should load always the auto dshow graph build a chain of 3x claudfx.ax ?
Why it load the filter 3 times?
a friend cant use zoomplayer with costum filter settings to force the filter load so i was thinking to change the dshow merit to 00800001 so the filter autoloads every time pcm data are rendered.
But i noticed that dshow load the filter 3 times in a chain before it connect to the dshow audio render finaly?
Is there a way to protect the filter to load multiple times or a other way to add a dsp filter like this to a player wich dont have full costum filter access and use the dshow auto render?
AndyIEG is offline
