Product to REPLACE HTPC's and STB's- Comments PLS!! - Page 3 - AVS Forum | Home Theater Discussions And Reviews
Closed Thread
post #61 of 64 Old 02-06-2004, 07:53 PM
kirkfrey's Avatar
My suggestion is to look at the AudioTron and how it works, borrow the basic ideas and apply them to video. Also, I’d rather have something that looked more like a standard component. Add an internal web server and I can replace (maybe) my AudioTron.
Oh, If you could make a 2 zone version that would be cool as well….
kirkfrey is offline
post #62 of 64 Old 02-06-2004, 08:17 PM
jimre's Avatar
The Joyport is nothing but a small form-factor PC motherboard (VIA EPIA, actually) in a weird-looking box, running some home-grown Linux "thin media client" software. There is no unique value whatsoever in this hardware - any one of us could build the same box for far less than you're charging. Your entire value proposition therefore lies in the quality & completeness of your software.
Unfortunately - even with great software ( a big IF ), I think you're too far behind the curve on hardware. The EPIA motherboards are woefully underpowered. Assuming Roku ever gets their software complete, I think their HD1000 hardware would wipe the floor with your Joyport for less money.
jimre is offline
post #63 of 64 Old 06-17-2004, 04:25 PM
slocko's Avatar
did joyport die? their domainame is for sale.
rather be lucky than good.
slocko is offline
post #64 of 64 Old 06-17-2004, 08:15 PM
RTK
RTK's Avatar
Quoted: 115 Post(s)
isn't the joyport in the same category as the Dlink Medialounge?
http://www.dlink.com/images/products...M-320_view.jpg
http://www.dlink.com/images/products..._interface.jpg
Rick
RTK is offline
Closed Thread Home Theater Computers
