Using Firewire to transfer files between computers? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 01-23-2004, 04:53 PM - Thread Starter
wbcollegekid's Avatar
Quoted: 35 Post(s)
Liked: 30
To transfer files between computers using firewire, do I just simply connect them and let windows automatically configure a connection. Or do I need to do something additionally. I would like to transfer a 500mb file. Any info would be appreciated.
Epson Home Cinema 5040, Yamaha Aventage 3050, Phillips BDP-7501, PlayStation 4, Energy Connoisseur Series 7.1.
wbcollegekid is offline
post #2 of 2 Old 01-23-2004, 05:31 PM
stephen2002's Avatar
Share a folder on one of the systems and then just plug them in and wait a little while. Windows will usually have the shared folder come up under "My Network Places". If it does not you will have to make it see the folder manually:
1. Open a command prompt (Start -> Run; "cmd.exe")
2. Type "ipconfig"
3. On the other computer open My Network Places, click "add a network place", then Next, then "Choose another network location."
4. Type \\\\[ip address]\\[folder name] and then click next.
Your folder should now be visible and you can just drag and drop files as if it were a local drive!
stephen2002 is offline
Closed Thread Home Theater Computers
