HDTVtoMPEG2 latest version - Page 31 - AVS Forum | Home Theater Discussions And Reviews
post #901 of 2239 Old 11-07-2005, 03:24 PM
Stereodude's Avatar
Quoted: 3093 Post(s)
Liked: 2239
Originally Posted by Cris Moore View Post
Do you know what MPEG2Repair does to "fix" the output TS files so that they do play?
I'll look into it more tonight.
I can post or e-mail you the text file of the errors it reports as corrected. The nVidia transport file input filter doesn't seem very robust. I suspect the problem is minor formatting. I can also provide you with a before and after file. I'll also try to see what error the nVidia filter is reporting.
Stereodude is offline
post #902 of 2239 Old 11-08-2005, 05:08 PM
Stereodude's Avatar
Liked: 2239
Ok, I looked into it some more, and it seems the problem only exists for transport streams captured by my Fusion 5 cards, but not for my MyHD 100.
The log files created by MPEG2Repair are uninformative.
post #903 of 2239 Old 11-08-2005, 05:33 PM
Cris Moore's Avatar
I guessing that the problem is probably do to the timestamp discontinuities caused by cutting the stream with H2.
Will the stream play back on the MyHD or Fusion card?
Will the stream play back with another decoder like NVidia(TheaterTek) or Elecard?
Cris Moore is offline
post #904 of 2239 Old 11-08-2005, 06:32 PM
Stereodude's Avatar
Liked: 2239
Not sure (haven't tried it yet), Yes
MPC can play it, as can windows media player, and TT.
post #905 of 2239 Old 11-21-2005, 01:07 PM
Cris Moore's Avatar
Latest version of HDTVtoMPEG2 v1.11.76 is available here.
Main new feature is a totally re-written commercial scanner (HDTV support only).
Cris
NOTE: When updating to this version the relationship between the output formats and the file extensions will be messed up. Either update the .Ext extensions manually or just delete the .ini file and start over.
.76 - Fix to scan code to handle pre-defined Include\\Exclude sections correctly during scanning
.75 - F5 refreshes the input file data if you are editing a TS file that is currently being recorded.
.74 - Files are now opened with FILE_SHARE_READ and FILE_SHARE_WRITE
.73 - Minor changes
.72 - Ability to disable .TRI file creation using the CreateTRIFiles=0 flag in the ini file
.72 - .TRI files not created until an Include, Exclude, button is pressed
.71 - Fixed major bug when Scan filters were being used
.70 - Jockeyed around the manual editing buttons
.70 - New Commercial Scan code (HDTV support only)
.56 - Changed default Channel to now be the first stream with a horizontal size >= 1280.
.55 - Default output file type is now transport stream instead of mpeg2. Last used setting is still saved in the .ini file.
.55 - File type list order is now Transport Stream, HiDTV, Mpeg2.
.54 - Default Channel is now the one with the lowest video PID number
post #906 of 2239 Old 11-21-2005, 01:19 PM
sterno3's Avatar
Thanks Chris...
I have been wondering about this for a week or so now, is there a feature in H2 (or another tool) that would allow a 'zoom' of the picture when processing it.
I will give you an example of why i am wondering. I recorded the Sat. Night Live gone commercial a couple weeks ago. I was hoping to archive the program. It is 98% 4:3 ratio, and it came as pillarboxed 1080i from NBC. I used H2 to remove the commercials, and then used Nero Vision Express to burn it to DVD.
The thing is, when viewed on a normal 4:3 tv, it is postage stamped (letter & pillar boxed).
Do you (or anyone) know of a slick way of zooming in when processing?
thanks,
Latest verson of HDTVtoMPEG2 v1.11.76
PLEASE DO NOT PM\\email me to send you the latest version. Give Balazar a chance to update the download site.
Cris
.73 - Minor changes
sterno3 is offline
post #907 of 2239 Old 11-21-2005, 01:37 PM
Cris Moore's Avatar
If you want to "change" the video you will have to re-encode the video with something like VirtualDubMod and Avisynth. Hardware players like the MyHD and Roku (using MPlay) allow you to Zoom 4x3 to fill the screen.
post #908 of 2239 Old 11-21-2005, 05:30 PM
Wendell R. Breland's Avatar
Quoted: 288 Post(s)
Liked: 157
Cris, thanks again!!! It will be week till I can try.
Wendell R. Breland is online now
post #909 of 2239 Old 11-21-2005, 06:23 PM
TPeterson's Avatar
Quoted: 235 Post(s)
Liked: 30
Cris has been hard at work and produced a fantastic feature in the new scanner! Run, don't walk, to the download.
Thanks, Cris!! (We love you, man! )
TPeterson is offline
post #910 of 2239 Old 11-21-2005, 06:32 PM
Stereodude's Avatar
Liked: 2239
Don't want to be a complainer, but the commercial scan doesn't work on DHDT.
post #911 of 2239 Old 11-21-2005, 06:48 PM
Cris Moore's Avatar
I assume the commercials on DHDT are 16x9?
post #912 of 2239 Old 11-21-2005, 06:56 PM
TPeterson's Avatar
Quoted: 235 Post(s)
Liked: 30
What is "DHDT"? It only works on 16:9 HD programs with 4:3 commercials, if that's what you're talking about.
post #913 of 2239 Old 11-21-2005, 07:04 PM
Cris Moore's Avatar
What is "DHDT"?
I believe he is talking about Discovery HD Theater.
post #914 of 2239 Old 11-21-2005, 07:08 PM
TPeterson's Avatar
Quoted: 235 Post(s)
Liked: 30
Oh...I didn't notice that they had commercials when it was unencrypted on my cable.
Anyway, if that is what he meant then, yes, it's all 16:9, as are InHD, ESPN-HD, etc. Although sometimes they have static side pillars that H2M might detect as "4:3" material. However, that is often actually program content in those cases.
post #915 of 2239 Old 11-21-2005, 07:11 PM
Stereodude's Avatar
Liked: 2239
Yes, it typically has a single 1 minute commercial about 22-25 minutes into the show and the shows end around 44-50 minutes into the hour.
post #916 of 2239 Old 11-21-2005, 07:19 PM
RalphArch's Avatar
Cris - works great for me - thanks so much for your time and effort
RalphArch is offline
post #917 of 2239 Old 11-21-2005, 07:47 PM
MickeyDora's Avatar
Commercial scan works great and very quick...my NBC station has local ads with a 16x9 blue bars so the scan misses them but it takes me less time to fix that than it would to edit all commercials. Killer feature...
MickeyDora is offline
post #918 of 2239 Old 11-21-2005, 10:49 PM
Nrmf's Avatar
thank you for the nice and fast program...but one bug i think...i joined 2 files captured from myhd 130 card...2 part eipisode of CSI and commercial scan gets first episode but must get confused on second file cause it makes it completely red..anything i can do.
thank you
Nrmf is offline
post #919 of 2239 Old 11-21-2005, 10:50 PM
MickeyDora's Avatar
I love this new scan but I have a quick question...
I captured a three hour block with three one hour shows. I ran the scan and it picked up all the commercials with no problems. How do only select the first show and mark the last two shows "exclude" and if I want to do the middle show how do I exclude the first and last show...same for third...Is there a way to delete all the edit points before/after the selected point? If not I may have to do them manually.
post #920 of 2239 Old 11-21-2005, 11:21 PM
Cris Moore's Avatar
@Nrmf,
Were the files already joined when you tried to scan them or were they two separate files (or multiple files) that you were going to scan and then join when you Processed them?
@MickeyDora,
Manually mark out two of the shows with Excludes then run the Scan. Process that show then repeat. You can also use the Delete key to quickly delete marker points. Each press will delete the prior marker point and "walk" backwards. Be careful as this last technique might require a little practice to get skilled at.
post #921 of 2239 Old 11-21-2005, 11:37 PM
Cris Moore's Avatar
@MickeyDora
Looks like I've got a bug when trying to scan a file with Excludes on both ends. On a 1-hour show consisting of two files, if I Exclude sections on the front and back and try to process and Include section in the middle that crosses file boundaries, the scanner stops at the second file.
post #922 of 2239 Old 11-22-2005, 07:04 AM
rramesh's Avatar
I like to split DVD vob files into my own definition of what a chapter is. Can I use HDTV2MPEG2 for this? I mean I loadup the vob and pick a start and end point (preferably frame accurate) and I like a vob file of the portion selected. Is this doable with this tool? Please forgive me if this is a naive question. I tried to get the answer from the thread but I could not.
BTW, I suppose I could do the above if it is a HD .ts file. Am I correct?
Ramesh
rramesh is offline
post #923 of 2239 Old 11-22-2005, 07:08 AM
hdtvincr's Avatar
I've only tried the scan once on Desperate Housewives. It got close on most commercials, and missed one entirely. It was one entire file.
The speed of the scan was awesome though.
hdtvincr is offline
post #924 of 2239 Old 11-22-2005, 09:10 AM
TPeterson's Avatar
Quoted: 235 Post(s)
Liked: 30
What was the source of the file? (OTA/cable, Fusion/MyHD/???)
post #925 of 2239 Old 11-22-2005, 09:11 AM
TPeterson's Avatar
Quoted: 235 Post(s)
Liked: 30
Ramesh
The editing tool works only on transport streams (.tp files), not MPEG-2 program streams (.mpg or .vob files).
post #926 of 2239 Old 11-22-2005, 09:30 AM
MickeyDora's Avatar
@MickeyDora
OK...I think I figured it out.
I have a three hour transport stream that is 18GB (single file) and it has three shows on it (Surface, Las Vegas, Medium). What I did was to exclude everything from the very first frame. Then moved forward to the very first frame of the first show and marked it in. Then went to the last frame of the first show and marked it out. Hit scan and all worked out fine.
I repeated the process with the second and third show and it worked flawlessly. Thanks again. This feature sure saves lots of time.
post #927 of 2239 Old 11-22-2005, 09:42 AM
hdtvincr's Avatar
OTA using MDP-120...
hdtvincr is offline
post #928 of 2239 Old 11-22-2005, 10:12 AM
TPeterson's Avatar
Quoted: 235 Post(s)
Liked: 30
...and the sw version? Was it "subchannel only" capture? (Your dentist must hate you )
post #929 of 2239 Old 11-22-2005, 10:18 AM
Nrmf's Avatar
Chris
they were 2 seperate files that i was going to scan and process into one.
Nrmf is offline
post #930 of 2239 Old 11-22-2005, 10:25 AM
TPeterson's Avatar
Quoted: 235 Post(s)
Liked: 30
Originally Posted by Nrmf View Post
Chris
Who's "Chris"?
Reply Home Theater Computers
