HDTVtoMPEG2 latest version - Page 37 - AVS Forum | Home Theater Discussions And Reviews
post #1081 of 2239 Old 01-10-2006, 01:21 PM
Huskerfan's Avatar
Quoted: 17 Post(s)
Originally Posted by HDTVFanAtic View Post
Despite the name, conversion became the least thing this program was used for.
I understand this. Would I just be better off with HDTV2DVD then?
Ya know, since I started this "hobby" I can't believe the many different programs on Doom9, VideoHelp, etc. that will convert, extract, encode, capture, split, edit, play, backup, reauthor and on and on and on...... Hell, I quit watching Sportscenter months ago!
Husker Nation is strong!
Huskerfan is offline
post #1082 of 2239 Old 01-10-2006, 01:25 PM
Cris Moore's Avatar
Yes, because conversion to mpeg2 capabilities were broken ages ago.
If you need that find a very old version that supports it properly.
There is NO version of H2M that supports conversion properly. The success of any version of H2M to create a usable program stream has A LOT to do with the source transport stream. That's why it works for some people and not others.
Cris Moore is offline
post #1083 of 2239 Old 01-10-2006, 02:18 PM
TPeterson's Avatar
Quoted: 235 Post(s)
Liked: 30
If making DVDs is your goal, yes, absolutely! (Although you'll probably want to use H2M to chop out commercials before you feed the stream to HDTV2DVD)
TPeterson is offline
post #1084 of 2239 Old 01-10-2006, 02:25 PM
hjohns1's Avatar
Also, Anyone know why the HDTV2DVD link would not be working? Gives me a 403 forbidden error.
http://software.badgerit.com/HDTV2DVD.html
The correct link is here...HDTV2DVD
hjohns1 is offline
post #1085 of 2239 Old 01-10-2006, 02:26 PM
Huskerfan's Avatar
Quoted: 17 Post(s)
Oops! sorry I didn't mention my end result. Yes, saving to DVD is my end result. Problem with these DVR's is that they only give you so much storage space and I'd like to have the show to watch in the future. And mostly I'm capturing concerts and/or movies so there usually aren't any commercials. Thanks a lot for everyone's input.
post #1086 of 2239 Old 01-10-2006, 02:29 PM
Huskerfan's Avatar
Quoted: 17 Post(s)
Thanks hjohns1. Yes, you go to that page and when you click on the download link (about half way down the page) it takes you to the link that I provided and gives me a forbidden error.
post #1087 of 2239 Old 01-12-2006, 10:06 PM
guptown's Avatar
Hi all! This is my first post to the HTPC forum so go easy.
I can't believe I have been working 3 days on getting my .ts files combined into one lage .ts file. I have hopes that I can then use the one .ts file and the disk2tape function on my modded r5000 receiver to send it to dvhs for archiving.
So I have 42 .ts files. Each one plays beautifully on the VLC player on my computer. Then I go to HDTVtoMPEG2 (v107) and try to combine the files into one large .ts. I add all 42 files to the queue and I rename the output file name to "movie".ts (from 00000000.mpg) and hit convert. This is a ~8GB movie and the resulting "movie".ts file is a puny 3KB file that is blank when I try to play it on the VLC player.
I have searched this thread and around the net and I can't seem to figure out what I am doing wrong. I just want to join all the .ts file into one.
Any help would be much appreciated.
Ray
guptown is offline
post #1088 of 2239 Old 01-12-2006, 10:12 PM
TPeterson's Avatar
Quoted: 235 Post(s)
Liked: 30
Seems to have been a transient problem. It works again now.
post #1089 of 2239 Old 01-12-2006, 10:14 PM
TPeterson's Avatar
Quoted: 235 Post(s)
Liked: 30
Ray
If H2M was showing "mpg" for its output file, it was in MPEG output mode. You need to change it to output Transport Stream.
post #1090 of 2239 Old 01-14-2006, 09:38 PM
niceguy321's Avatar
Wow, I had that same exat problem. Thanks
Edit: how exactly do I do that
niceguy321 is offline
post #1091 of 2239 Old 01-14-2006, 10:47 PM
TPeterson's Avatar
Quoted: 235 Post(s)
Liked: 30
Look just above the output filename field for the dropdown menu named "type" and select Transport Stream.
post #1092 of 2239 Old 01-14-2006, 11:33 PM
Huskerfan's Avatar
Quoted: 17 Post(s)
It worked when I got home. So it could have been a privacy issue with my work computer, also. Anyways, it's all good now.
post #1093 of 2239 Old 01-14-2006, 11:35 PM
TPeterson's Avatar
Quoted: 235 Post(s)
Liked: 30
No, the site was giving me a 403 error earlier on the same computer, so it wasn't your change of venue that solved it.
post #1094 of 2239 Old 01-14-2006, 11:50 PM
Huskerfan's Avatar
Quoted: 17 Post(s)
Huh. Glad to know I'm not going totally insane.....Although some days I wonder.......
post #1095 of 2239 Old 01-15-2006, 10:45 AM
niceguy321's Avatar
I don't see that option, I just see this one
Edit, not enough posts, here-
agprojects [dot] net / pictures / h2m [dot] JPG
post #1096 of 2239 Old 01-15-2006, 10:58 AM
Cris Moore's Avatar
Your using a very old version. Get the latest version here.
post #1097 of 2239 Old 01-15-2006, 11:08 AM
Shape's Avatar
Quoted: 67 Post(s)
Liked: 88
Any chance that this program could be updated to open up the *.dvr-ms files that MCE spits out? Apparently they are just transport streams in a wrapper.
Josh - GamerTag: ShapeGSX PSN: ShapeGSX
'97 Eclipse GSX - 11.825@117.55mph in the 1/4
Shape is offline
post #1098 of 2239 Old 01-15-2006, 12:11 PM
curtis104's Avatar
Ray
You can try a software called TotalCommander to join your .TS files. Works for me flawlessly.
Curtis
Xbox Live ID: Blaze104
MSI Media Live DIVA 5.1
Ahanix MCE701 case
LG Blu-ray/HD-DVD
3 Cable Card
1 HDHomerun
Windows 7 32bit
42" HP MediaSmart
WHS Norco 4020 case w/ WHS 2011
curtis104 is offline
post #1099 of 2239 Old 01-15-2006, 12:39 PM
Cris Moore's Avatar
Probably not. Not that it couldn't be done. It's just that H2M was architected to handle native transport streams. It doesn't have the ability to walk around junk that may be in the file in order to find the transport stream. I think my time would be better spent fixing the current problems in H2M than in adding support for other file formats.
I would think that you should be able to find a tool to convert from dvr-ms -> TS format or purchase an app that can handle that format directly like VideoRedo.
post #1100 of 2239 Old 01-15-2006, 04:28 PM
niceguy321's Avatar
Ha, thanks, I had no idea that my version was old. I just did a google search and downloaded that one. Thanks for the link
post #1101 of 2239 Old 01-15-2006, 04:51 PM
Shape's Avatar
Quoted: 67 Post(s)
Liked: 88
I've managed to extract an MPEG2 from a DVR-MS using graphedit, but it is a bit of a pain, and runs the film's speed. So a 2 hour video takes 2 hours to extract.
Shape is offline
post #1102 of 2239 Old 01-15-2006, 06:32 PM
Cris Moore's Avatar
To me it doesn't make any sense that Microsoft would have took a complete fully functional transport stream and just put a wrapper around it for no reason.
It makes more sense to me for them to have taken the program stream out of the transport stream and put that in the wrapper.
If there really was a full-blown transport stream in the dvr-ms file then you shouldn't have any problems with playback after extracting the transport stream.
post #1103 of 2239 Old 01-15-2006, 06:45 PM
Shape's Avatar
Quoted: 67 Post(s)
Liked: 88
They put a wrapper around it in order to protect it with DRM. Though I am not sure that every DVR-MS file is protected.
You may be right that they strip the video out of the transport stream as the program is recorded to the drive.
Shape is offline
post #1104 of 2239 Old 01-15-2006, 06:54 PM
Cris Moore's Avatar
Right. I forgot about the DRM stuff.
I took a quick look at VideoRedo's FAQ about DVR-MS. It can read the files in and edit them and write out a mpeg file but some players have audio sync problems so they are currently treating it as an "unsupported" feature.
post #1105 of 2239 Old 01-15-2006, 10:37 PM
guptown's Avatar
Solved the problem. The newest version of H2M does not give you the option to output it as Transport Stream. I found an older version of H2M and it works like a charm. Thanks for your help.
guptown is offline
post #1106 of 2239 Old 01-15-2006, 10:41 PM
Cris Moore's Avatar
I will have to disagree with that statement.
post #1107 of 2239 Old 01-16-2006, 12:20 AM
TPeterson's Avatar
Quoted: 235 Post(s)
Liked: 30
I don't know what "newest version" you're looking at, but all the ones linked from this thread offer that option. I expect that H2M author Cris Moore was very shocked to hear that he's removed its most used output mode (in a delirium?).
post #1108 of 2239 Old 01-16-2006, 10:35 AM
tall1's Avatar
I never knew this was an option. I would simply change the filetype of the output file to .TS Playback still works ok. What differences are there between .TS and .MPEG output files?
tall1 is offline
post #1109 of 2239 Old 01-16-2006, 10:44 AM
TPeterson's Avatar
Quoted: 235 Post(s)
Liked: 30
None...besides the fact that they're different protocols entirely.
Try Googling "MPEG" and "Transport Stream". (In the above context, "MPEG output" means "Program Stream", BTW)
post #1110 of 2239 Old 01-16-2006, 03:34 PM
tall1's Avatar
I googled, still dazed and confused. Maybe I'm too stupid to post here but I don't see any differences whether I playback a native .TS file or a H2M .MPEG file. I have also successfully archived both filetypes to my DVHS which led me to believe the only thing that was different was the filetype. I guess not but for the life of me I don't know why you would want one filetype or protocol over the other.
tall1 is offline
Reply Home Theater Computers
