Dual monitor - DVD player 2nd screen - AVS Forum | Home Theater Discussions And Reviews
post #1 of 19 Old 07-05-2004, 07:12 PM - Thread Starter
mzemina's Avatar
I am looking for a DVD player that can run on the second screen of a dual monitor setup. But I also need the controls to be displayed on the primary display while the full screen display of the DVD is on the second display. In addition I also need the program to always lock the displays so the full screen always appears on the second display and the control is on the primary. When I shut down and restart the application I want all to appear on those monitors with no additional settings having to be made.
Does anyone know which application can handle my requirements?
Mike Zemina
mzemina is offline
post #2 of 19 Old 07-05-2004, 07:27 PM
taoshen's Avatar
both WinDVD and PowerDVD does that..but I prefer the interface of PowerDVD and IQ of WinDVD.
taoshen is offline
post #3 of 19 Old 07-06-2004, 06:51 AM - Thread Starter
mzemina's Avatar
I have used WinDVD (came with the DVD-ROM) and couldn't get it to work. Maybe I need to purchase PowerDVD? Is the manual/help informative to show me how to perform what I am looking to do?
Thanks for pointing me in the right direction.
Mike
mzemina is offline
post #4 of 19 Old 07-06-2004, 07:14 AM
larsbo's Avatar
Win dvd works perfect on sec. screen.... Zoomplayer can be used as well if you want to use various codecs.
Larsbo
larsbo is offline
post #5 of 19 Old 07-06-2004, 07:45 AM - Thread Starter
mzemina's Avatar
Larsbo
Yes WinDVD does work on the second screen. BUT, it does not (at least the version I have) keep it's location when you close it down and restart it. Plus to get it (the DVD window, not the controls) to the second screen you must drag it over there. All items I am not looking for. You you know how to get the DVD display to appear on the second screen upon launching (or keystroke method to get it to appear on second screen) that would be appreciated!
Mike Zemina
mzemina is offline
post #6 of 19 Old 07-06-2004, 11:24 AM
araghava's Avatar
if you use zoom, you can use the /F:[n] parameter to launch on the monitor of your choice.
araghava is offline
post #7 of 19 Old 07-06-2004, 01:13 PM
kami's Avatar
Zoom Player is the best for this. It has a setting to always launch fullscreen on the secondary display. I use it myself.
kami is offline
post #8 of 19 Old 07-06-2004, 03:42 PM
araghava's Avatar
kami,
have you had any problems with using zoom on the 2nd screen. quite often zoom will hang if i pause/rwd/ffd etc when i display on the 2nd screen. when i look up zoom in the task manager, it's consuming 99% of cpu cycles. my only recourse is to kill it. this never happens if i display on the primary monitor.
araghava is offline
post #9 of 19 Old 07-06-2004, 04:40 PM
kami's Avatar
No problems here. I am using a ATI Radeon All-in-Wonder 9800 Pro and my secondary monitor is my HDTV (component out). I've used ZP 3.2, 3.31, and 4.0 with no problems like you describe.
kami is offline
post #10 of 19 Old 07-06-2004, 06:11 PM
araghava's Avatar
thats exactly the same as my system except i'm using an ATI 9700. for some reason zp will hang on my 2nd monitor. i've tried windvd and powerdvd filters. i've had to resort to a batch script which changes my HDTV to become my primary, run zp and then switch back after zp ends.
araghava is offline
post #11 of 19 Old 07-09-2004, 05:27 AM - Thread Starter
mzemina's Avatar
Could I get a copy of your batch file? What commands (utility programs) are you running to make this change?
Mike Zemina
mzemina is offline
post #12 of 19 Old 07-09-2004, 10:22 AM
araghava's Avatar
Mike Zemina
i use a utility called vidres. it's freeware and allows you to change the video card properties. the batch file is fairly straightforward. i'll mail it to you when i get home.
araghava is offline
post #13 of 19 Old 07-10-2004, 10:08 AM
araghava's Avatar
you can download vidres from http://www.jddesign.f2s.com/vidres.htm
my batchfile is very simple.
"C:\\Program Files\\JD Design\\VidRes\\Vidres.exe" /P /M1
"c:\\Program Files\\zoom player\\zplayer.exe" /F:2 /R:(1776,1000,32,30,2) %1
"C:\\Program Files\\JD Design\\VidRes\\Vidres.exe" /P /M0
araghava is offline
post #14 of 19 Old 07-12-2004, 07:45 AM - Thread Starter
mzemina's Avatar
Many thanks for the information.
Mike Zemina
mzemina is offline
post #15 of 19 Old 07-12-2004, 08:28 AM
Thunderstokke's Avatar
Ultramon
Excellent dual monitor app. Is able to lock open windows and programs on the second monitor .. and adds ekstra buttons to the top of windows so u can easily change monitor without dragging the windows.
http://www.realtimesoft.com/ultramon/
You can also extend the windows toolbar to the second monitor and the program will minimize open windows on second monitor to the extended toolbar instead of the toolbar on main monitor.
Thunderstokke ( Denmark )
The Red pill or the Blue pill....what happens if i take them both??
Thunderstokke is offline
post #16 of 19 Old 07-12-2004, 08:39 AM
bcherb2's Avatar
Thanks for the command line shortcuts to zoomplayer thats a big help. Could you explain what the numbers mean though? For some reason my zoom player plays the video more towards the top of the screen and using your command line execution it worked right and was centered once, now its back to near top again. How do I get this video centered?
bcherb2 is offline
post #17 of 19 Old 07-12-2004, 11:17 AM
araghava's Avatar
you can find documentation of all zoom command line parameters at http://www.inmatrix.com/zplayer/parameters.shtml
the /F:2 tell zoom to open in full screen mode in monitor #2. the /R:(1776,1000,32,30,2) tells zoom to switch the resolution to 1776 x 1000 with 32 bit colour, 30 hz refresh rate on monitor #2.
araghava is offline
post #18 of 19 Old 07-12-2004, 01:23 PM
bcherb2's Avatar
Thanks, that works perfect -- except now zoomplayer's displaying the video towards the upper half of the screen....is there a way to center the video vertically and horizontally????? This will never work with my PJ...
Ben
bcherb2 is offline
post #19 of 19 Old 07-12-2004, 05:18 PM
araghava's Avatar
i've never tried this myself but you could try the /VX, /VY, /VH, /VW parameters to position the video. look up the command line parameters from the link in my earlier post.
araghava is offline
Closed Thread Home Theater Computers
